Hey Steve Spohn!!!!
Hey Steve Spohn!!!!
Dude I just saw your website and it is awsome you are the MF man!!!!! Hey do you know of anyone having any troubles with the TH400 swap in a 3rd gen? I have your cross member adapter and I just saw your pre made driveshaft which I will be picking up. Is there anything else I will need?
Brad, one of the Admin's here is my web designer, so the kudos go to him on the site!
If you have the complete torque arm kit, you're good to go. If you have just the crossmember, then you still have the torque arm issue to deal with.
The only other thing is the driveshaft, which you already know about. Other then that, it's an easy swap, there are no tunnel clearance issues or anything of that sort, the TH400 fits in there fine.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Steve
No, tranny lines are long enough, so is the shifter cable.
