Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Bosch Plugs
Old Jan 2, 2004 | 10:28 AM
Dr. Suess's Avatar
Car: 1986 Chevy Camaro IROC-Z
Bosch Plugs
i need some info on the
Bosch Platinum +2
and
Bosch Platinum +4
Old Jan 2, 2004 | 12:10 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
All you need to know in reference to those plugs and our cars is don't use them. If you have a civic or some other car like that with the plugs in the top center of the bore then it's ok, with v type engines they only cause problems.
Old Jan 2, 2004 | 05:08 PM
25THRSS's Avatar
what he said. I personally really like the design of the NGK's the best of all I have seen. Don't buy into the gimmic stuff.
Old Jan 2, 2004 | 05:16 PM
Dr. Suess's Avatar
what plugs do you guys suggest i hate gapping my plugs so that is why i was going for the bosch platinums
Old Jan 3, 2004 | 12:49 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
AC's dont like to gap? Takes like a minutes to do all 8
Old Jan 3, 2004 | 10:27 AM
Dr. Suess's Avatar
how about Delco Rapidfire and if not what plugs do you guys use and which ones are the best to use in our cars
Old Jan 3, 2004 | 10:29 AM
formul8!!'s Avatar
Car: 2004 GTO
You cannot re-gap Delco Rapidfires. The coating will flake off and cause a bad spark.
I have been using plain old Bosch Platinums for many years in my L98 with never a problem.
Old Jan 3, 2004 | 01:46 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
NGK are good in a bike but for a car I have had my best luck with Accel U grove plugs. They last forever and never foul. They have never become a weak part of my Ign.
Old Jan 3, 2004 | 02:06 PM
Dr. Suess's Avatar
which one of these is the better plug to go with
Accel 0574
Premium Plug: U-Groove Resistor Spark Plug;
3 Month Limited Warranty
Ships in 5 days
Weight: 0.4 lbs.
$1.99
or
Accel 0274
Spark Plug: U-Groove Standard Spark Plug;
Ships in 5 days
Weight: 0.4 lbs.
$1.99
or
Accel 0574
Spark Plug: U-Groove Resistor Spark Plug; Tapered; Projected; 0.625 in. Reach Plug;
Ships in 5 days
Weight: 0.4 lbs.
$1.99
or
Accel 0574S
Spark Plug: U-Groove Resistor Spark Plug; Taperd; Header Projected; 0.625 in. Reach Plug;
Ships in 5 days
Weight: 0.4 lbs.
$3.59
i am asking because i always just used Bosch Platinum +4's but after going thru the board it seems that they are not worth it and how often should i change these plugs i always never changed my + 4's because they said they were good to 100000 miles any help would be appreciated
Old Jan 3, 2004 | 02:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Not sure man? I get the ones behind the counter at Advance Auto [ was Parts America ]. In the 8 pack box. $15-$20.
Not everyone stock them. They are usually behind the counter with the Accel coils n wires in a one rack display.
Old Jan 3, 2004 | 02:22 PM
Dr. Suess's Avatar
actually now that i think of it i will put all my options and someone tell me the best ones to go for
Autolite Ignition APP24
Premium Spark Plug: Double Platinum; Gap .035
$3.97
Autolite Ignition AP24
Premium Spark Plug: Platinum; Gap .035
$2.48
Autolite Ignition 24
Standard Spark Plug: Gap .035
$1.24
AC Delco R43TS
Standard; Resistor; @ Gap .035" @; Tuned-Port Injection $1.58
Delco Rapidfire 1
Gap Pre-Set At Factory; @ Do Not Re-Gap @
2 Year Replacement Warranty
$3.99
Bosch 4207
Platinum Part: Gap .035
Lifetime Replacement Warranty
$2.14
Bosch 4302
PLATINUM2: Do not Gap
$3.99
Bosch 4449
PLATINUM+4: Do not Gap
$5.99
Bosch 4302
Platinum2 Plug: Gap Pre-Set; For 4449
$3.99
Bosch 7575
Super Part: Gap .035
$1.09
NGK 7401
Platinum; UR4VX; @ Gap .035" @; Tuned-Port Injection
$6.99
NGK 6630
V-Power; Resistor; UR4; @ Gap .035" @; Tuned-Port Injection
$1.68
Champion 3018
Spark Plug: Platinum Power; 8 Req. Per Vehicle; Gap .035 $2.98
Champion 18
Spark Plug: Copper; 8 Req. Per Vehicle; Gap .035; Plug No. {RV15YC4}
$1.28
Accel 0574
$1.99
Accel 0274
$1.99
Accel 0574
$1.99
Accel 0574S
$3.59
Accel 8171
Spark Plug: U-Groove Standard Blister-Pak Spark Plug; 8 pc. Of #0274;
$15.99
Accel 8177
Spark Plug: U-Groove Resistor Blister-Pak Spark Plug; 8 pc. Of #0574;
$12.99
Accel 8198
Spark Plug: U-Groove Spark Plug Header Plug; 8 pc. Of #0574S; $29.98
and the award for the most expensive plug goes to
NGK 2834
Platinum; D9EVX; @ Gap .024" @
$9.59
Old Jan 3, 2004 | 02:23 PM
Dr. Suess's Avatar
these are all advance auto parts plugs
Old Jan 3, 2004 | 02:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I was a tad off on the price it was 15-20 bucks for 8
I got these in my Bird
Accel 8190
Spark Plug: U-Groove; 6 Pack
I got these in my Buick
Accel 8180
Spark Plug: U-Groove; 8 Pack
I also have the matching Accel coils on them both.
But I like Kem wires better.
You would want the
Accel 8171
Old Jan 4, 2004 | 09:39 PM
RaMaiRGoD69's Avatar
Car: 88 GTA
spark plugs
i have had nothing but good luck with my platinum +4s
Old Jan 5, 2004 | 10:03 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
The way I see it....if you're gonna spend all that cash on the +4's, hell, might as well go all the way and buy some Iridium plugs. Autozone started carrying it...but I can hardly justify the price. Or those new Halo type, with the ring ground electrode. Those look killer. Expensive as hell and tricky to find though.
Old Jan 5, 2004 | 11:31 PM
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
How about get a reliable spark for cheap and get a set of NGKs? Then you'll have money to buy an airfoil or maybe a billet tuned port injection plate or possibly a chrome dipstick. Those at least don't hurt performance and cause detonation while retaining the uselessness and extravagance of the Bosch +4s.
Old Jan 23, 2004 | 01:45 PM
MHarris's Avatar
Car: '92 Firebird w/T-Tops Black w/Tan Interior
Engine: 305 TBI
Transmission: 5 Speed
Where are you getting your info from Inwo? I've ran Bosch 4's for 60K and have had no problems. I actually got a faster start and better mileage. Is that just your own experience or have you seen it somewhere else?
Old Jan 23, 2004 | 04:08 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I went from Splitfires to Delco Rapidfires and really enjoy the AC Delco. Provides for a smoother idle in my case.
Old Jan 23, 2004 | 04:58 PM
Pat Hall's Avatar
Splitfires are just a gimmick plug. I can sum up autolite plugs and wires in one simple phrase "Don't Do It!" Autolites are probably the worst ignition parts I've ever disgraced any of my vehicles with. I'm kinda lukewarm on Bosch plugs as well. I had an old Toyota and had my girlfriend at the time pick up a set of plugs. She brought home a set of autolites. It had terrible pick up with them. I replaced them with Bosch platinums and it was like night and day. However, the Bosch plugs seem to work really well in the four cylinder engines, but everyone I know who's used them in a V8 weren't very happy with them. I usually run standard Champion resistors in my V8's with great results. The last time I did plugs, I used standard AC Delco, which work pretty good, but it seemed to run a little more powerful using the Champions. I can't knock good old AC Delco plugs for longevity though. I once removed a set from an engine with 93,000 miles on it and they still weren't misfiring! The electrode was burned down at a forty-five degree angle so bad it was almost non-existent, but they never missed.
Old Jan 23, 2004 | 11:35 PM
Nixon1's Avatar
I dont think there is any kind of rule for a bad plug really....what someone else thinks is a crap plug, another persons vehicle runs great with it. I think it just boils down to, what works for you. Every engine is different.
Old Jan 27, 2004 | 06:49 PM
benoit454's Avatar
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
bosch plugs are junk no matter what they ar ein less its a ford which is already junk lmao.
i wouldnt hit a dog in the *** w/ them.
i had a lil 5 hp go cart that u run regualr plugs in i put in a bosch plug and blew it apart no ****.
the porcelain blew off the plug. not to mention soon as i put it in the thing jumped n jerky n spit n coughed.
was aweful they are completely junk.
and also if they have them 2 and 3 or 4 prongs on em some can actually burn holes in top of pistons.
from burnin too hot or something.
dont waste yur time takin out yurs to put in bosch plugs and dont waste money on em.
youd be better off using motorcraft or auotlite plugs in em since thoose are factory ford plugs.
bosch just sucks pure nasty stinky funky *** crack
Old Jan 27, 2004 | 07:34 PM
DJsyclone's Avatar
I did a minor tuneup on my aunt's 91 Chevy Cavalier, I replaced the plugs with Bosch Platinums and the car runs much better. The old plugs were in bad shape though. I use Platinum +4's on my car but I may try NGK because I use one on my motorcycle and it seems to be the best plug for it.
Old Jan 28, 2004 | 12:49 AM
bytal's Avatar
Car: 88 Pontiac GTA
Engine: 5.0L
Transmission: Manual
i'm changing my plugs next month and i'm going to go with NGk platinum. i was thinking about the iridium but then.. the extra 4bucks/plug doesnt seem justifiable
Old Jan 28, 2004 | 08:51 AM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
I seem to have the best luck with either ac delco or NGK platinum.
Old Jan 29, 2004 | 12:13 PM
Nixon1's Avatar
Ive thought about running Iridiums too, but then...my car is never running 'perfect' due to a highly modded motor and really stock chip. And something tells me those Iridiums, with such a tiny electrode, would be easy to foul.
Old Jan 29, 2004 | 07:05 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I combined the Bosche +4 platinums with my MSD balster coil and they fouled out in 2000 miles. They are pure garbage and I wasted a crap ton of money on them. HEi systems send to much juice to them and they fould out really bad in a short amount of time. They are perfect for small cars with weak ingnition systems. I should say they are really good for small cars. Better throttle response and mileage but stay away from them for f-bodies. Just get plain old AC delcos and be done with it. You are not running anything exotic that will need crazy plugs.
Old Jan 29, 2004 | 10:39 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Then you have a problem. The idea with platinum plugs is longevity. And here is the concept with multiple electrode plugs;
It is not to make 2, or 4 sparks, it is to allow the spark to travel the path of least resistance. This means you will get the fastest, largest spark, most consistently; this is all for peak efficency. If your car burns oil, runs rich, or doesn't run healtily, then you will foul a Bosch platinum plug. I ran a set of Bosch single electrode platinum plugs in my Camaro for a year, and I will take a picture for the sake of this thread they looked so outstanding I kept them. I only removed them to put +2 series plugs in. I use an MSD box, 8.5mm MSD wires, Flame Thrower Coil and Control Module, and NASCAR series cap and rotor, with these plugs it can't be beat unless you want to talk about a multiple coil pack conversion kit from MSD. For a healthy fuel injected vehicle, it's hard to find a better plug if you ask me, namely the +2 and +4 plugs.
Old Jan 29, 2004 | 10:49 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
See that is the thing. I have no problem period. The car runs great and had about 29,000 miles on it when I took them out, I replaced them with AC delcos and the stumble and hesitation went away. I don't think they are a true platinum and the conductivity is poor and they corrode very quickly. They are platinum coated and I think they have coating iussues that account for the mixed results. I am very aware of the advantage of least resistance and this has happened to many people besides me. There is no such thing as a faster spark. They don't seem to like a hot spark. You seem to be an exception. This is interesting because I know you have a good combo that runs really well. Maybe it is a quality control thing. I have to do a little more reasearch on platinum conductivity an corosivity. I cannot remember off hand.
Old Jan 29, 2004 | 11:06 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Autolite platinum plugs have a dab of platinum at the end, Autolite double platinums have platinum on both ends, and the the Autolite triple platinums have platinum throughout the entire plug. Similarly, the Bosch platinums have platinum through the entire length of the plug - that's the best I know about platinum content in "platinum series" plugs. Sorry to hear you had bad luck with them
Car: Camaro
Engine: 355c.i.
Transmission: th350
spark plugs are wierd...
every car will run different with different ones, my dads 396 in his nova worked well with certain NGK's but not others, my car didnt like ac delcos but like autolites (i think it was the delcos it hated) i think you should just try out some for yourself. but why spend money on expensive plugs if you dont need them. try the cheapos and see how they work.
Old Jan 29, 2004 | 11:14 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I will get back with you on this. You have a great combo so that makes me wonder why it didn't work with me. I don't make ground ripping power but combustion for similar motors should differ than much. Be prepared for a nerd answer. I am going to ask some questions with some material experts here.
Old Jan 30, 2004 | 12:38 AM
25THRSS's Avatar
They are absolute crap. Ever wonder why people cut back the electrode slightly to expose the spark more? All the plus 4's do is do the exact opposite to what you want to do. It's a gimmic.
Old Jan 30, 2004 | 02:12 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
To improperly insulate the center element so it functions improperly with distorted spark characteristics?
Old Jan 30, 2004 | 02:30 AM
25THRSS's Avatar
I would expect an ignorant reply like that from you, but no suprise, you are wrong. You want to have a large spark exposure, which plus 4's obviously do not have. They have 3 useless electrodes blocking the spark. This is what you want.
http://www.gmtips.com/3rd-degree/dox...tion/spark.htm
Old Jan 30, 2004 | 02:44 AM
25THRSS's Avatar
Here is another pic showing what you want. The opposite of the gimmic known as plus 4's.
http://www.sparkplugs.com/glossaryImage.asp?imgID=42
This helps expose the spark to the mixture and protects against pre-ignition from an overheated ground electrode. Don't buy into the plus 4's as they cause more harm than good. The only advantage I can see using them is if you never plan to change your plugs again, in which the extra 3 electrodes can be used as the others slowly wear down over a long period of time, but the other 3 will still be uselessly blocking the mixture to the spark. As long as you do regular maintainence to your vehicle, the standard single electrode plug is far, far superior than any of the gimmic plugs out there.
Old Jan 30, 2004 | 01:07 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Yes, edited; I don't even want to waste the time to argue something so stupid.
Old Jan 30, 2004 | 02:32 PM
MHarris's Avatar
Engine: 305 TBI
Now come on children lets play nice or we'll turn this forum around.
Old Jan 30, 2004 | 08:14 PM
25THRSS's Avatar
Ignorant simply means misinformed or that you don't know. I'm ignorant on a lot of stuff myself. I can admit it. No flame intended.
Old Jan 31, 2004 | 04:15 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Here is the truth behind the compatability issue of platinum plugs with HEI systems. I will try to keep this as non nerdy as possible so that you guys can understand a bit. I had a lengthy converseration about this with my buddy who to is also a mechanical engineer but curren;t working on his Ph.D in materials. Who better to ask then him. Platinum is one of the most conductive materials there is. However corosion is also proportional to conductivity. Meaning, that the higher the conductivity the higher the rate of corosion. So the more current and voltage you send to platinum the faster its rate of corrosion. Cars with less powerfull ignition systems get away with this and benifit from the higher conductivity. Because standard plugs do not conduct as well they in turn do not corrode as fast and provide a relatively long life span with a hot spark system like the HEI. I can go into a little more detail if this does not make sense to some people. So it is not that the plugs aren't any good, it is just that they aren't a good choice for our applications. Just selecting heads and cam combos. Just because it is better doesn't mean it will work well.
Old Feb 5, 2004 | 06:20 AM
Pat Hall's Avatar
Good explanation there Shifty. Makes sense to me. Bosch platinums worked great in the little toyota I used to have, but they've never impressed me much in a good old chevy v8.
Old Feb 10, 2004 | 11:20 PM
Lance Donlon's Avatar
Car: 91 1500 ex-cab pickup
Engine: 350 vortec
Transmission: 5-speed
I well just stick with good old factory ac delco sparkers like platinums in stock vortec motors
Autolites suck
Old Feb 11, 2004 | 01:11 AM
  #42
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Spark plugs are like toilet paper. Try some out until you find the one that works best. If its too soft try a different ply. If it pulls your @ss hair off when you wipe, dont use it. Same with plugs. Find what your engine likes to run and go with those.
Old Feb 11, 2004 | 08:04 PM
  #43
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I have run the 4+ bosch and can't really say anything bad about them, had no problems whatsoever, I didn't notice anything different either though. Just go with some regular plugs, I don't think the bosch are worth the money, but they are good plugs.
Old Feb 12, 2004 | 05:41 AM
  #44
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
Well, I've had nothing but a good experience with +4's as well and I'm also running them with a MSD Blaster coil. As a matter of fact I put 15,000 miles on them and then pulled them out to do the headers and they still looked great. Work fine for me but that's not to say that some bad ones don't exist. I work in the auto aftermarket and quality isn't always perfect. I've had some really bad experiences with Champion plugs.
Old Feb 12, 2004 | 12:54 PM
  #45
Nixon1's Avatar
There's something about Champions I don't trust. They just seem like cheap, white-trash plugs...
Old Feb 12, 2004 | 02:52 PM
  #46
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
What we need is a platinum spark plug with a provision for a burn-off system just like the MAF sensor (with its platinum wire) has.. now THAT would be an expensive plug...
BTW, if anyone is looking to buy standard plugs with the cutback ground, you can get the autolite racing plugs: AR3924 in my case..
Here's a pic:
Old Feb 12, 2004 | 04:23 PM
  #47
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
if your engine is stock just use a stock ac delco plug. if you think its a pain to gap plugs i suggest you dont work on a car.
seriously, its JUST a spark plug.
Old Feb 15, 2004 | 03:25 PM
  #48
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
They DEFINITELY work well in small engines. I do my experimenting in my Hyundai. 1) it's cheaper to spend the money on only four plugs, and 2) it sooooo easy to change them in the four-cylinder!
I put Splitfires in my little '95, and the car took off like a rocket!!! To whomever said it's a gimmick, it's not! That plug is for real! So when I got my new little 2000 car, I immediately changed the plugs. But this time I decided to see how the Bosch plugs would work, and I put in +2s. They were nice and smooth, but they didn't seem to produce the power that the Splitfires did. And now after 90,000 miles, I just changed from my +2s(which were still in fine shape, considering they had 90,000 on them) to +4s.
The multi-electrode plugs definitely provide for a smoother running engine, based on my experience, not my opinion. As for power, Bosch didn't make the noticeable difference like the Splitfires did.
As for how they perform in our V8s, I've only run the regular Bosch Platinums--but for about for 90,000 miles now. The engine still runs very strong. I haven't tried any of the multi-electrodes or the Rapid Fires in it yet, but that's my plan.
And as for the pix on above posts, cutting back the electrode makes for a wider gap and a longer spark, hence providing a bigger, longer explosion and a more complete burning of the fuel giving the engine more punch. That's nothing new. That's why racers do it. And that's what the theory is behind these "ready-made" plugs. And as I said, from my experience with small engines, they definitely do. And they should in a larger engine, too.
But everyone's set-ups are different, so every engine is different. There'll never be one product that works perfectly in every situation. That's why the "fine print" says something like, "depending on the application."
I only know what I've tried. And I'm pleased enough to try one of the performance plugs in my Formula very soon. I'd like to go with the Splitfires, but I need a plug that I can keep in, well, forever, at this point in my car's life, lol--especially since they're such a pain to change! So I'll probably go platinum.
Old Feb 15, 2004 | 06:44 PM
  #49
Nixon1's Avatar
I think Autolite now makes "race" plugs, that have the electrodes already cut back, right out of the box. For the lazy people (like me). I've been curious to try those expensive Iridium plugs...but I don't like those itty bitty electrodes, as cool as they are.....
Old Feb 15, 2004 | 06:53 PM
  #50
thirdgen88's Avatar
Car: 1995 Corvette
Read more of the thread next time...
