Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Tires
Old Jan 6, 2004 | 07:49 PM
RachaelRider16's Avatar
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
Tires
Can I fit tires that are P195\40\R16 on the back of my '89 Camaro without too many problems?
Old Jan 6, 2004 | 08:21 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Why in the world would you buy a tire that small ?
Old Jan 6, 2004 | 08:59 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Snow tires maybe? Hmmm, don't know abotu that size. What size is your rim, 16 I presume.
Old Jan 7, 2004 | 12:05 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
thats an awfully small tire it would fit with no problems whatsoever, though i dont even think thats an actual available size....
Old Jan 7, 2004 | 09:51 PM
Car: 1989 Camaro RS
Sorry! I meant 295! My bad.
Old Jan 10, 2004 | 08:21 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
Old Jan 10, 2004 | 08:23 PM
Kontrax's Avatar
Car: 86 Camaro
companies dont make that size, if you want a 295 you have to get a 15 inch wheel. the biggest you can do on a 16 is a 255 and in drag radials you can go slightly bigger. i would never buy another 16inch wheel again after i found that out. also, if you decide to do a 295 tire, watch for rubbing on the inside of the well. i have 295 50 15 rears but my car is lifted a few inches and i barely have enough room because of those rubber guards that keep the axel from hitting the body. im thinking of cutting them off and fabing the wells.
one more thing, you have to use a 15x8 or larger. the stock 15x7's are to narrow and the tire could dismount on turns. WAY to much play in the sidewalls. i suggest going with a 15x9. the tires will not only fit great but they will also give them the appearence of being bigger then they really are. i am currently using a 15x8 and i wish i had gone 15x9 but i got all 4 wheels for 100 bucks...not to shabby
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
