Spark Plug Wires? Which do you recommend
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Ok here is my application... I am 99.9% sure that I will never run my car at a track ( but you never know, closest track to me is about 2 hours away so I might take it for a run down a 1/4 mile next summer just to post some numbers).
I want to have a street performer though and I am looking at upgrading some parts. Couple of things that I am going to do is wires, ignition(maybe a MSD 6AL ), plugs (maybe AC Delco Rpaid Fires), air foil (yeah I know it ain't much but it helps a little
) gut the air intake and put a couple of K&N drop ins. I will also be putting in a custom chip in the spring
As time goes on heads and headers will be looked at. etc etc
Anyway what wires do you guys recommend? I was thinking a set of Taylor Spiro Pro's..any suggestions?
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Check out my ride in the Readers Rides
https://www.thirdgen.org/rides/index...ew&rideid=6920
Better to look at it than to look for it
) gut the air intake and put a couple of K&N drop ins. I will also be putting in a custom chip in the springAs time goes on heads and headers will be looked at. etc etc
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
I highly reccomend the Taylor/Vertex Spiro Pro Blue silicone 8's. They did wonders for my car, but mine were the Delco-Packard's on a car with 140,000 miles on it.
I had some experience with Taylor's in the past...had them on my 92 Sunbird GT (V6) and I did notice a small difference...especially coupled with 6 AC Delco Rapid Fires. So I guess I will go with these (seeign that I can get them locally)
Personally I don't think ignition upgrades are all that effective..well I guess every little bit helps but not like intake and exhaust mods.
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
i had the taylors and upgraded to the msd 8.5's......i didn't feel any difference.
street or strip; you should get the best you can afford, but i would look else where until you start getting some real power down. free up the breathing of that car with a nice header and exhaust combo as well as a good intake....you'll be a lot happier.
all the nickle and dime things add up; why not save and go for what really works. that is unless your ignition system is faulty and you need to replace it then i say go with the msd box and wires. otherwise your spending alot of money on something that won't give you any gains. (at least at a stock level)
I also vote for the Taylors; Had them for about 3 mos now and no problems. They look nice too. Good thing to see you are starting in the right place; a full tune up (cap rotor wires plugs filters) and you might want to think about replacing the O2 sensor also, they get fouled up after a while and I bet you will feel a difference w/ a new one. Then start flowing some more air in (intake mods) and slap on a full exhaust and your car will move nice! An MSD box is nice to have but I'd presonally buy a set of headers before that, just my .02 Good Luck w/ the car
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I have the msd super conductors. No complaints.
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Serpentine Setup
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
1987 Iroc 350
K&N filters
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Serpentine Setup
Holley afpr
FUTURE GOAL:
Some pics of it at
Car: Damn
Engine: This
Transmission: New Stuff
I have had bad luck with my Accel 8.8 race wires. They were leaking voltage, and the stock ones did not. I am going to Taylor.
White '88 RS (originally 2.8)
Previous engine-350, .040 over, vette alum. L98s, stock tpi, stock 305 injectors & chip. TES headers & edelbrock cat back. 3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 357-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
New Setup:
4 bolt 357 (10.2:1), AFR 190s (fully cnc ported), LT4 Hot cam (1.6 RRs), Ported SuperRam (upper&lower), Ed Wright custom chip, 24# Accel injectors, Yank 3200 lock-up TC, 3.27 9 bolt rear, some traction! Hoping to see some 12s.
on a 2.050 60 ft.
(Damn the 2.8!)
New Setup:
Car: 1992 Z28
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by arthur:
I would check out the Jacobs wires. The ones with the ceramic boots are great if you have headers.</font>
I'd reccomend the MSD 8.5 SC's and the Moroso BlueMax wires. They have low resistance and are fairly tough.Supreme Member
Car: Faster
Engine: Than
Transmission: You!
call summit racing, order the MSD 8.5 super conductor wires for your year/model car, then order mallory pro-shield and pro shield heat shrink, take on boot off of each wire, slide the proshield over the whole length of the wire, and heat shrink both sides of the wire (between the boot and the start of the proshield. You should never need another set of wires for the life of that motor. The pro-shield is resistant up to 1200 degree's I think. Works perfect for header applications!
Check out the latest issue of HOT ROD magazine. They have a article on spark plug wires from all the top mfg's. They rate them by various
functions and performance. You will be surprised by the results. I have the Splitfire Dual Mag wires.
I also have the Splitfire Dual Mag wires, and I like them, but don't expect much improvement over stock unless your old wires are trashed, and don't waste your money on fancy spark plugs either.
92 Camaro RS 5.0 5-Speed
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
14" open air cleaner
1998 Dodge Ram SS/T
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
1998 Dodge Ram SS/T
Yeah I know what you are saying about the "fancy" gimmicy plugs. I think I will be going with a set of Taylor Vertex Spiro Pros and a set of plain ol' AC Delco's when I change out the plugs and wires.
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
