G Tech Pro help needed here...
Ok, I just got it and plugged it in... and nothing! I read the troubleshooting guide in the back of the book but that doesnt match up, then I made sure the fuse was good and that the lighter would work, and they do. This thing will not light up for me at all. All I have to do is take it out of the box, plug it in and turn the switch to something other than OFF and I'm good to go right?
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You should be good to go, try moving it around in the plug and see if that works or try another car.
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,ES LCA and Panhard bushings,free mods.
0-60 5.2s
Track Time
60' 2.049
E.T. 14.14@96.7MPH (2270 FT)
13.76@99.4MPH corrected
0-60 5.2s
Track Time
60' 2.049
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
mine did the same thing. Do like above and move it around in the plug worked for me
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Serpentine Setup
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
1987 Iroc 350
K&N filters
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Serpentine Setup
Holley afpr
FUTURE GOAL:
Some pics of it at
Mine does not want to read 0-60 unless you are doing a 1/4, did no problem before.
http://sites.netscape.net/bulldogfrazier/homepage
http://www.fracoinc.com/
Keep your ride shinning with pride
