Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Eagle and JE?
Old Oct 15, 2004 | 12:33 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Eagle and JE?
im planning to build a 383 this winter for the camaro.
i was thinking of the Eagle ESP 4340 Forged Crank and the ESP 4340 Forged Steel H-beam Rods.
for pistons i was thinking of running JE pistons, forged ofcoarse, flat tops with valve reliefes. i want the motor to run on 89 octane pump gas.
if anyone has any experiance with these products let me know.
Old Oct 16, 2004 | 09:02 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I'm running Eagle Forged Rods and Crank with JE forged flat top pistons...no problems so far. Just be careful with your compression ratio if you want to run on 89 octane.
Old Oct 17, 2004 | 02:37 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
yeah your best to not have compression much higher than 9 to 1 if you wanna run mid grade
Old Oct 17, 2004 | 02:20 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
I ran 9.4:1 compression on 87 oct with no problems so as long as you stay under 10:1 I'd say your safe with 89 oct.
As for the J/E/ Eagle combo, I run a eagle 4340 crank and H-beam rods with custom JE pistons on my 412 with no problems.
My friend ran a 9.9 on his 412 with the eagle forged 4340 crank and H-Beam rods with J/E pistons. So they can handle power nicely, but we did have some fit ment porblems with the Eagle crank.
Old Oct 17, 2004 | 05:39 PM
92MaroRS's Avatar
could you please go into a bit more detail here?
Old Oct 20, 2004 | 02:28 AM
louich's Avatar
Car: 75 firebird..9.30@150.5
Engine: twin turbo pump gas sbc
Transmission: glide
Axle/Gears: 3.42s
nothing out of the ordinary, just had to clearance the block and bottom of the cylinders a bit for the rods to clear them, the h beams give lots of cam clearance but come closer to the oil pan rail area, my big block runs a 4.625 stroke, now that takes some clearancing
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Nervous2
Oct 8, 2015 10:53 PM
86z89iroc
Oct 5, 2015 01:04 PM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
