Summit roller rocker
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
I found these 1.6 steel roller rockers from summitracing.com
part nr Sum-141507
Are these any good i mean the price is only 99.95 for a complete set and since im on a budget it sounds really nice.
Will i need stud girdles for these ??
part nr Sum-141507
Car: 1985 Trans Am
Axle/Gears: 3.70
I would not cheap out on anything drivetrain related. IF you can't afford good roller rockers, then hold off. Theres a reason why some cost $100 and others cost $250 and it ain't just cause of the name. I went cheap on my last set of rockers and paid for it with 2 ruined lifters and a $300 camshaft in the trash.
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Originally posted by Scania
Ok , should i use steel or aluminium and do i need stud girdles.
Car: 1989 Corvette
Engine: 350 Tpi
Ehm, yes its a 305 and im looking for an easy way out instead of changing the cam i thought i go with the roller rockers. Im also going to change the rear axel ratio to a richmond but i havent decided what ratio i should buy.
Engine: 4.0L
OK, since you're not doing a big buildup you don't need steel roller rockers or girdles. You would do fine with stamped steel roller tipped rockers, they are cheaper then aluminum rooler rockers.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Summit roller rocker
part nr Sum-141507
part nr Sum-141507
-- Joe
school boy
Oct 22, 2015 11:47 AM
KO1
16
Oct 15, 2015 05:00 PM
