msd box location?
Car: 1984 Camaro Z28
Engine: Turbo V6
Transmission: 200r4
msd box location?
anyone have any pics on the location of an Msd 6al not sure where i want to mount it??
mine is mounted inside the car on the passenger side of the console.......away from the heat, moisture and vibration
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Most either have it on the firewall on either side, or I have seen quite a few mounted on the strut tower on drivers side...
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
I also have my MSD 6AL mounted on the inside (for the same reasons as previously mentioned by 383backinblack), along with my Blaster coil. Since I removed my heater core, I mounted both the MSD module and coil where the heater core used to be:
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I mounted mine above the battery. Made a small aluminum shelf like so....
Car: 89 IROC-Z
Engine: 355 L98
Transmission: 2.77 700R4 Auto
Nope - it's an MSD Digital 6+
Originally posted by Tony Walch
Not a very good pic but you get the idea
http://www.team3rdgen.com/modules.ph...view_photo.php
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Here is mine. Mounted on the drivers side firewall where the relays use to be mounted.
1 Post
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
Same as above. Beside the master cylinder see it here www.89formula350.com
Engine: 4++,350 & 305 CIs
Originally posted by KiLLJ0Y
how about mount it in the garbage can.. thats the best place for those things
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Originally posted by TunedPort 335
Way off on the right hand side, i made a metal plate/bracket and mounted it to that.
ive got mine hid in the glove box.
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Originally posted by stage20
holy moly your engine is clean!
PS i am jealous of your 4th gen "glovebox"
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Thanks man!
Thanks man!
we even?
Car: 1989 IROC-Z Convertible
Transmission: Art Carr 700-R4
msd location
I've got no pictures, but I mounted my 6ALBTM underneath the front air cleaner housing (which is no longer used because I have a vortech). You can only see it if you're looking for it. It was a real pain to install there, however.
Car: 86 camaro
Engine: l69
Transmission: t5
i mounted my ignition box on the passenger side of the firewall by the ac,but ive seen people even mount it near the mastercylinder on the driver side of the firewall
msd box location
I really have to make it a point to sit down and reply to these posts when I have time to do it properly!! As sometimes it happens, I failed to include some important details about my installation. I've got a 6AL-BTM and these units are a little bit wider than the regular 6AL, so mounting it on the firewall anywhere is a bit more difficult. It may very well be possible to do so, but I simply didn't take the time to do all of the necessary measurements in the "normal" underhood locations. Another important note: MSD claims that one should try to shield the box from heat. I guess I was a little paranoid, but I didn't want to chance a catastrophic failure. The heat of the California desert in summer (which i spend time in each year) is so intense that this is actually a possibility. I could be wrong, but why risk it??
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Hey i was wondering how you guys that put the msd on top of the non ac box got the rubber mounts on from the back?
i drilled one hole on the top left and went inside tried to reach my and up but could'nt get to it.
thanks
thanks
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Here's mine...Made a bracket for it behind the strut area...
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i agree that i didnt notice a big difference with the msd as far as power goes but it seems to idle alot better with it
Car: 1989 PONTIAC FORMULA - 1992 PONTIAC TRANS AM
Engine: BOTH 5.7L 350
Transmission: BOTH 700-R4
Originally posted by mw66nova
an msd box on a stock motor will show little to no improvements in power, but will help on mpg. on a modded motor, you'll see more power improvements.
It depends on the car… my close to stock WS6 (LT1 car) saw .2s and .12mph at the track with an Accel 300+ box but I couldn’t feel much of a difference on the street (although when I put colder plugs to run N2O I found that I would get misfire codes without the accel box that went away with it). I moved that box to the L98 formula and saw a similar increase, then when I knew that I was going on a road trip I moved it to my K1500 and saw a consistent 2mpg increase.
In all cases the car has a better/smoother idle and feels torquier off idle and at cruise. Especially the truck which has always been a little rough and cranky feeling down low and wasn’t extraordinarily happy with even the stock, .035” spark plug gap.
I decided to leave the 300+ on the truck and after doing a bit of research (and actually finding an engineer that worked for both accel and now crane and talking to him for close to an hour) I decided that I’m replacing the 300+ and accel coil on the formula with a Crane HI-6TRS and an LX92 coil. I’m going to leave the stock coil with the 300+ on the truck because it should give a more appropriate spark for the application.
The Crane HI-6 is significantly larger (almost 2x) then the accel box which is why I’m asking the question about mounting. With the accel box begin so small I could literally put it anywhere (I actually just had a piece of 2 sided 3M body/trim tape on the back side of it and had it stuck to the back of the driver’s side strut tower), where with the Crane box “anywhere” just won’t fly.
I picked up a used Crane HI-6S I'm going to do some experimenting with as well.....
#42
1 Post
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
i dont have any pics but i mounted mine in the center console. cant see it very clean and very easy to get to the rev chip
#43
You can see what I ended up doing last weekend:
https://www.thirdgen.org/techbb2/sho...postid=2528962
#44
Car: 92 Camaro B4C 350
heres a link to my cardomain site with a pic of where i put my 6A box... mounted it in the console, had to remove the console's center brace but it fit in there perfectly.... and its away from the heat, moisture, and vibration from under the hood
http://www.cardomain.com/ride/2120412/1
#45
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
I think mines is in a pretty cool place on the inside of the drivers side fender infront of the winshield wash fluid container, one question guys, i bought my car with the the box already installed is there a quik check i can do just to make sure its even working ?
#46
mounted my MSD-6AL on the drivers side strut tower, sticking out rearwards towards where all the relays are mounted. used clay to make sure I had clearance for hood closing. might have to un-mount it if I have to replace some of the relays (MSD blocks access). spliced in a 2' length of cable to reach the starter for batt power. used the MSD adapter to connect to the GM dual-connector coil (makes it so much simpler).
I use the MSD simply for cleaner running plugs, stronger spark, and hopefully it will fire fouled plugs a little longer before I have to replace them on my tired engine.
#47
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
mine is mounted where the stock computer is... fits right in the computer tray and all pretty nice... of course, i have no need for that POS ecm lol
#48
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Mine is on the firewall, on the driver side. It fits nicely there but beware: it makes a constant buzzing noise and it is quite obvious with the windows up, mostly at idle (when I'm driving the exhaust is loud)
The supercharger got rid of this problem though. How you ask? The whine of the SC makes the buzzing unable to be heard
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
