Trickflow heads
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Trickflow heads
Hi!
Someone hawing experience from roller rocker arms to fit the trickflow heads,the stock or some aftermarkets dont seemes to fit very well.
I have tryed compcams 1.6 ratio alu lifters and on the intake side the rollertip on the arm like roll over the center of the valvetop,on the exhaust it is a little better but not perfect.
There must be very bad pressure if you run like that insted of hitting the center of the valve top.
If someone haveing done some mods on these heads let me now.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like maybe you don't have the right length pushrods. Where the rocker contacts the stem isn't as important as how far it moves across the stem though.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Well there are experience makanic who told me that it doesnt matter what length of the pushrods are if the rockerarm dont hit the right spot at the valve,even whith lash caps its not ok and safe to run whith the rollertip over the edge he says.
And why is it different on intake then on exhaust?
Anders
Anders
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the geometry of the arms is controlled by the pushrod, if it is going off then of the valve stem, you need the correct sized pushrod.
See this acrticle from Comp Cams, on the geomitry of this stuff. If your mechanic say's its the rockers, he is an idiot.
http://www.compcams.com/Technical/Products/Pushrods/
Engine: 383 Carb
Transmission: 4L60
Car: 1989 Firebird Formula 350
Transmission: 700
Hey Firebird Sweden,
Your pushrods are the problem as others mentioned. I encountered the same problem when I had a mustang. I purchased trickflow twisted wedge o-ringed heads and got a set of crane pushrods because Summit was out of the Trickflow pushrods and they told me this is a substitute brand. I also purchased new roller rockers, lifters, cam, etc. About 6-8 months later I had a bad valve tap. I checked everything out, removed the springs and noticed slop in several valve guides. I called a tech rep at Summit and he told me that I should have never used the Crane pushrods becuase they were too short. I got new valveguides and purchased the correct pushrods and if ran excellent! If the roller doesn't sit in the correct spot on the top of the valve then you have a geometry problem = pushrod length. You will eventually get uneven wear in the valve guides.
Like the other person said...talk to a different mechanic!
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok
Maybe its me having problem to explain the problem,i will attache a photo of the valve,you can see the difference betwen intake and exhaust valve,is that right to be an 1,6mm difference?
Car: 1990 Camaro RS
I still think you could fix it with the right pushrods.
Which heads are those? They look like a twisted wedge head, I didn't think trickflow made TW heads for chevy's.
You might also call trick flow. It could be that those heads were designed to use a 1.5 on the intake, and 1.6 exaust, with custom lenght pushrods.
Engine: 383 Carb
Transmission: 4L60
Changing the rocker ratio changes the distance from the pushrod cup to the fulcrum on the rocker, not the distance from the stud to the valve on the head.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Yes you are right that chould not make any different,still why are they not equal.
Yes they are twisted wedge head.
I have give trick flow a mail but they have not answer yet.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
7.2 stock roller cam
7.8 stock flat tappet
and tell your mechanic that pushrod lengths do matter
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok
This is the aswer from trick flow.
The difference is where the rocker stud hole is drilled in the trunion. On
the intake rocker it is drilled a little off center
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
