Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
When to use longer pushrods???
Old Sep 19, 2000 | 02:16 PM
Biochem's Avatar
Car: 2002 SOM z28
First I had gotten 1.6 rollers for my 305 and the guy said I also needed longer pushrods. I learned very quickly that longer pushrods = very crappy idle.
When I built this engine, I got Performer heads and they said you need longer pushrods. My idle is bad (not as bad as it was with the 305)... do I need stock length?
I can't seem to idle worth a crap under 1000 rpms. If I do go to 750, then it wants to surge like a vacuum leak, but I cannot find one for the life of me.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Sep 19, 2000 | 07:13 PM
Guest
Guest
Posts: n/a
Ahhhhhhhh, pushemrods...
What you need is a pushrod length that will place the contact point of the rocker arm and valve stem right in the middle of the stem in the middle of the lift of the valve. This will make the contact area between the rocker arm and valve stem as centered as possible most of the time.
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
