Posi
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
There were tons of ratios available and there's no real way to tell unless you pull the cover off and look. I have an 89 RS and it was a 3.42, but that doesn't really mean anything. Also I had an open and installed a posi, I looked on the boards and also on ebay for one. You have to make sure that you get the right series carrier (posi) for whatever gears you have. Also you have to make sure that you get one for a 9 bolt or a 10 bolt, whichever one you have.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i beleive yours came factory stock with 2.73s (yuck). You would probably want 3.43s or 3.73s you will need the series 2 carrier when going to a 3.43 o higher i beleive (don't quote me).
As for posi's board favorites are detroit lockers or the auburn pro.
Make sure you buy a posi with the correct spline setup for your application also (28).
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Factory V8:
Automatic: 2.73
Manual: 3.08
Open Differential
28 Spline
Factory V6:
Automatic: 3.23
Manual: 3.42
Open Differential
28 Spline
Find yourself a 4th generation rear with a Posi 3.42 that came out of a 6 speed manual. For about 300$ you can get Posi, 3.42s, and disc brakes.
Automatic: 2.73
Manual: 3.08
Open Differential
28 Spline
Factory V6:
Automatic: 3.23
Manual: 3.42
Open Differential
28 Spline
Deroit true track! - best unit I've ever owned. Far superior of control, plus really street friendly.
as for gears, most likely 2.73...
- 3.42 I wouldn't go any lower(numerically higher) unless you have/intend on many mods....
- 3.42 I wouldn't go any lower(numerically higher) unless you have/intend on many mods.... Junior Member
Car: 86 T/A
Engine: 383 stroker N/A
Transmission: th350
Axle/Gears: 4:11
Originally Posted by crrllmich
Factory V8:
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
posi for sale
I have a compleat posi 10 bolt rear 4.11 gears disk brakes all new parts I am about to list in the parts for sale section (I have about $1100 invested) $700.00 I also have a factory 3.42 gear set for it $100.00, I also have a posi unit out of a 2000 TA with 3.23 gears 35k miles on it perfect condition 28 spline $175.00.
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Does that mean that if it has 3.08 or lower STOCK its a series 2 and 3.42 and up STOCK is a series 3 or is depending on which gear you choose during the swap?
Car: 86 T/A
Transmission: th350
Axle/Gears: 4:11
KO1
16
Oct 15, 2015 05:00 PM
