Energy Suspension vs Ground Control bump stops
I foolishly ordered "one" of these from G.C. thinking it was a set(was not), instead of paying another $8 shipping.I found these on ebay from Energy.They are actually for the datsun 260/280zx line, but are virtually indentical to the G.C. by dimension.Anyway has anyone by any chance used these.Here's a pic. P.S. G.C. bump stop for sale.
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
hey man im looking for some energy suspension bump stops for the front any idea where to find them?
I got mine on ebay for $17.81 shipped from Motor City Imports, part# 7.6104G.There # is 1 866 322 8886.I tried everywhere for these locally.All the big auto stores & every one of them was out of stock.The only other place was summit, but they only had them is red.
Car: 88 IROC
are they a good bit shorter than the stock ones, im running intrax springs so they have to be pretty short? i took my stock ones out and threw them away do these come with bolts? thanks for your help.
They are a donut type design & slide onto the strut shaft.There are no bolts needed/required.They stand just under 2inches & are 2in wide at the bottom & 1 3/8 top.The hole is about 7/8in(24mm) at the bottom & about 1 1/4in top.You could probably cut these down if you wanted to.Its just polyurathane anyway.
1992 Trans Am
05-10-2023 07:19 PM
ProtoMaster22
08-26-2015 07:50 AM
eightsixseven
08-14-2015 03:09 PM
