Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
slp runners
Old Jul 8, 2006 | 03:10 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
slp runners
i insalled the new slp runners on my z,needless to say i`m not impressed,anyone else satisfied with there`s
Old Jul 8, 2006 | 04:58 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
I have them on mine and they work pretty good but to really get the full effect they need to be port macthed to the plenum and base.
Old Jul 9, 2006 | 07:47 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
What other mods have you done to your engine, unless you have any other items that will increase the flow of both air/fuel through your engine you will more than likely not see a huge increase, now if you have a nice set of headers and exhaust, a little better cam and even a little better flowing set of heads, and mayebe even an AFPR, you would see a lot larger increase. Like Derek said you would have seen a better gain also if maybe you port match to the base, and do a little plenum work. But as far as just bolting a larger runner on you now get a tire schredder by doing just that. If you dont want to do all that, them at least put a AFPR on it and bump it up a little and you will see a lot better gain. Good Luck.
Old Jul 9, 2006 | 11:08 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
They were on my '87 IROC-Z LB9/G92 vert when I got the car. The car also had the Edelbrock TES headers and SLP 2 on the left catback exhaust. I, naturally, was impressed with that combination compared to a stock combination fwiw.
Old Jul 13, 2006 | 02:57 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Check out the tech articles on the homepage. There is a write up on how to siamese the runners yourself. I bet if you did that, youd at least be somewhat impressed.
Old Jul 17, 2006 | 04:20 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
I've had mine on for 3 years and I like them. I did a lot of porting work on them and port matched them to the upper plenum. But I still want a stealth ram.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
