gauge install help??
Car: 86 Z28
Transmission: 5 speed
I'm going to install mach. gauges in my camaro tomorrow and was wondering where to punch the holes through oil pressure is 3/8 hole and the water temp is 7/8
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Why you going to duplicate guages, why not monitor something else?
On another note, I'm getting ready to install a tranny temp mech guage, so I'm looking for hints to.
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
because the factory gauges are crap? My oil press is pegged at 80psi unless It idles for 30 secs, then it comes down to 45-50. this 2.8 has over 160K miles I doubt my oil press is really that high. that said Im getting a set of electric gauges, oil press, water temp, oil temp, vac and will be mounting them under the center AC vents.
Why not do it right and fix the factory guages?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you could always replace the factory senders to solve your problem. Or do it like me and ditch the whole cluster, rewire everything and swap over to 8 autometer guages for around $1000-ish.
86IROC112
Aug 17, 2015 02:00 PM
