Question about summit double roller timing chain
I put it on yesterday and it feels real tight. The reason I went with the summit chain was because it was included in the rebuild kit. I have never used a double roller timing chain before, so I wasn't sure if this was normal or not. It has very little play,if any, so I wanted to check and make sure I did everything properly. any help would be great, thanks.
87'IROC-Z 350 TPI
Ported Plenum,Hypertech Air Foil,Ram Air kit,SLP headers,AFPR,80series flowmaster and MAF screens removed.
14.61@94mph(90+ degree weather)
87'IROC-Z 350 TPI
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Yep, it's supposed to be good and tight with no slack.. That maintains proper ignition timing vs piston position.
It may seem wrong since motorcycle drive chains and bicycle chains require a certain amount a deflection, but tight is right.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Jake
Jake
Jake
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
thanks, I haven't ever seen a timing chain that tight, so I just wanted to make sure it was right before I continued any farther. I guess I need to get off the comp. and finish this beast up today
. thanks again.
. thanks again. Thread
