Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
LCA relocation brackets
Old Aug 22, 2008 | 06:46 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
how much do they help in the launch? And will they allow me to power out of turns harder? Which setting is better 2" or 3"?
Old Aug 22, 2008 | 06:56 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: LCA relocation brackets
I thought they were for lowered cars... not sure how much help for stock height cars they would be... But someone with experience can chime in...
Raf
Old Aug 22, 2008 | 07:24 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
On a non-lowered car I think that aftermarket control arms would be more help then the relocation brackets.
But my cars lowered and I used to have no relocation bracket, it used to break traction if you slammed the gas from a stop, then I got it and put it at 2in with stock control arms and it wouldent break traction.
I recently added aftermarket control arms and I put it on 3in lower, so ill see how much that helps.
Old Aug 22, 2008 | 07:32 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
On a lowered car the relocation brackets put the LCA back at the correct angle.On a non lowered car they preload the rear I've been told.
Old Aug 25, 2008 | 09:36 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have them on my car.
It is not lowered.
With stock boxed control arms and lcarbs I have a best 60ft of 1.59(with bfg drag radials)
Old Aug 25, 2008 | 10:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
They are a tuning tool. Buy a set and try them. It's like a carb spacer, you can't just say they add xyz HP, you need to try it.
Old Aug 25, 2008 | 11:06 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I'm on stock rear springs on the 3" lower holes, and these help a ton. I need more tire, but have done a best of 1.44 60'. My old 305 did a 1.8 60' with street tires (radial t/a's) with this same setup.
Old Aug 26, 2008 | 10:16 AM
the widowmaker's Avatar
they do nothing more than adjust your anti squat and instant center. too little anti squat and youll never get traction on the strip, but too much and youll get an insane amount of rear brake hop under panic stops on the street. what you need depends on your car and its height, cog, tire height, uca angle, lca angle etc. its easy to graph out if you know what to look for.
Old Aug 30, 2008 | 04:19 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
ok cool. I plan on lower control arms too. I was just wondering if the relocation brackets would actually help. thanks.
Old Sep 1, 2008 | 08:18 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
same setup, i picked up .03 on the 60ft. which is a ton for a small item..
Old Sep 2, 2008 | 06:45 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
yeah. i got them bolted in, which was a pain but not as hard as it seems others had, and the car launches nicely. Lot more traction. I have it on the 3" setting. I can defintely power out of turns harder. Great upgrade. It feels like the back end is a little heavier though. Like its higher up. But who knows. Still feels solid. Gotta get them welded in.
Old Sep 2, 2008 | 07:44 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i had a set of spohn LCARBs and tubular lcas installed when i had my transmission rebuilt last year. back end felt awesome after the upgrade.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
