Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Best AFPR?
Old Dec 18, 2000 | 05:20 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Best AFPR?
Which is the best AFPR in you guy's opinon? Got the funds, the car isnt running right now any way, time to get one but which one?
87 Z28 305 TPI, Auto, 2.77, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47, 3.23 and SLP airfoil on the way!
Old Dec 18, 2000 | 05:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have a Crane. Its not the best but I like it.
Old Dec 18, 2000 | 06:29 PM
theformula's Avatar
They are all the same. One doesnt do something the other doesnt. Make your own and save the $70. Not worth $70 if you ask me. A piece of metal with a hole drilled in the top! If I knew about this article 6months ago I would of saved my loot.
Check out this link. Vader wrote this article. http://members.aol.com/mmmm999/3rd-d.../afpr/afpr.htm
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Stock throttle body, runners,intake manifold,cam, and heads.
Old Dec 21, 2000 | 08:50 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I dont know if you want to make your own or not but I have a Holley and it is super easy to adjust. It has a flat top that all you do is turn with your hands. I got it for $60 from www.carpartsonsale.com I dont know if the price is still that but it is worth a shot.
Old Dec 22, 2000 | 02:24 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Ilike the Accel unit because its not just a cover,it also has the new diaphram,spring etc.
D&Z Performance
"Putting Power to the Pavement"
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
