Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
made for you wire loom kit.......AWESOME!!!!!!
Old Dec 18, 2000 | 11:15 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
if anyone is debating whether or not to get the "made for you" wire loom kits, you should definitely get them!
i got the aluminum bracket kit that bolts into the whole(s) between teh exhaust ports on the heads, and the vertical wire kit. they are VERY high quality, and look AWESOME!
i am VERY impressed with them, and would recommend them to anyone that needs to clean up their engine bay. i will get pics up as soon as i can.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Accel Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Dec 19, 2000 | 12:19 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I've used aluminum wire looms in the past and found them causing some cross fire between cylinders. Check to see if yours are crossfiring by looking under the hood at night in a VERY DARK location. It's amazing what you may discover!
Old Dec 19, 2000 | 01:05 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I used their kit for centerbolt valve covers and it works great. The looms are made out of some sort of plastic (Nylon 6/6?) and are oil, chemical, and heat-resistant (up to a certain degree that I don't remember). You can see some pix of them on my website at:
http://www.erols.com/gcwestph/Headers.html
They even supply the longer bolts for the valve covers...
Greg Westphal
'87 IROC 305TPI/A4
Old Dec 21, 2000 | 04:45 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
those look great.
I seen them in summit catalog, but im definatly going to get them. my engine bay is a mess!
1982 Camaro Z28...$1000
Vortec 350 block rebuilt 20 over.. $900
L31 Vortec heads...$0 xtreme energy comp cam... $200
Edelbrock carb/intake...$500
home made cold air/ram air induction...$0
dynomax headers...$150
flowmaster 3chamber...$250
rebuild diff, 3.73 richmond swap... $900 built 7004r w/ stock converter... $200
Dusting a 2000 GT with my "truck motor"...
PRICELESS
Old Dec 22, 2000 | 07:24 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have motor pics of the just for you wirelooms installed on my TPI ZZ4. E-mail me if you want to see them (sorry no website). They look great, however a funny note. I burned 3 plug wires after installing them! Probably my stupidity. They do look great. Just tape the bottom bolt so it doesn't keep dropping out while installing the top retainer and screw. Manual dexterity is a must!
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Dec 24, 2000 | 10:27 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
here are the pics of the wireloom kits...
-brian
Jeremys87
Jul 14, 2022 09:08 PM
midge54
Sep 2, 2020 07:13 PM
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
