Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Summit 2 piece timing cover set
Old Jan 21, 2010 | 09:11 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
http://www.summitracing.com/search.a...UM-G3230&dds=1
Steer clear of this FAIL. Wow tried twice now to get it and the new Summit oil pan to go down, and forget it. Ok, It's in there, but with lotsa RTV to hopefully keep my brand new build up from oozing black gold all over the place. There are no instructions, ie: torque values, and using the shop manual values blew the paper gaskets to crap. It would not mate to the front of the new oil pan, so I took it apart, to evaluate. Well 4 of the 5 spot welds came apart. The chrome cover came with nice inside wrenching (read allen head) fastners, but the cover distorts way too easily. Tech support was resonable in help, though they confirmed that there were no instructions, and his recommended torque was the snug and stop. Tough to make an accurate oil seal with snugish. Dunno, me thinks it's better to stick witha steel factory style witha little paint.
Remember,
(RESULTS NOT TYPICAL, MILEAGE MAY VARY, and BATTERIES NOT INCLUDED!)
Old Jan 22, 2010 | 01:44 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Summit 2 piece timing cover set
That's lame
I've always had good luck with summit brand parts, never had an issue... So far at least
Old Jan 22, 2010 | 04:51 PM
Nah, let me say the summit stuff is great. I used their oil pan, timing set, push rod guides, and others just on this build. It should be widely known that there stuff is mostly if not all unmarked brand name stuff. This timing cover is also made by Mr. Gasket for 2 bucks more. Coincidence? Just no luck with this piece. Got my media blaster working today, and cleaned up the old stocker, fresh paint and installed now. Heads go on in the AM. later
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
MY87LT
Aug 17, 2015 08:43 AM
