Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Spohn Precision front end rebuild kit
Old Nov 10, 2010 | 05:39 PM
weaz4200's Avatar
Car: have a 92 camaro rs...in pieces
Engine: none now...probably 383 stroker
Transmission: none yet
Axle/Gears: none
Anyone use the Spohn Precision front end rebuild kit? No matter what I do the idler arm doesnt fit well onto the centerlink when the pitman arm is attached to the centerlink... And vise versa.... There was no problem with the old linkages... What gives? Should i send it back and ask for another kit? Im pissed.
Old Nov 10, 2010 | 06:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spohn Precision front end rebuild kit
how does it not fit well? what seems to be off with it? is the idles arm sitting too low?
Old Nov 10, 2010 | 06:22 PM
weaz4200's Avatar
Axle/Gears: none
I attached everything together before putting it on the car...
1st ... idler arm hooked up the the center link.. Was tightening the castle nut down and couldnt tighten it all the way cause the joint in the center link was spinning along with the nut.
2nd.... Finally got the nut tightened down (bottomed it out).. Was still too much free play.. I could grab the idler and move it up and down... I could tell it wasnt tight against the center link...
3rd... Attached the center link to the pitman arm and hooked up both outer tie rods to spindles.... No problem there... Now when i went to hook up the idler it didnt line up to the bracket on the body.
4th... Unhooked the link from the pitman arm and attached it to the body bracket... Now the pitman arm wouldnt go onto the center link flush... You could see that it was going on crooked... Mind you if i torqued it down on side of the pitman arm would have touched the centerlink and on the other side id be able to slide a quarter in.
5th.. Tried the reverse on 4th.... Hooked idler up to body (disconnected from the center link). Hooked link to pitman arm.. Tried to hook it to the idler and got the same gap as well as i cant get it tightened down cause the joint keeps spinning again.
I dont know what the issue is.... Its either the idler or the center link. IMO.
Question... The Idler arm should be a press fit right? Cause if thats the case it comes off without a puller.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
bellez77
Sep 5, 2015 08:39 PM
