Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
help which headers are more appropriate.
Old Nov 17, 2010 | 01:18 PM
383RAT's Avatar
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
I am trying to figure out which header tube size is more appropriate for my set up. I currently own 1 5/8 SLP headers and 1 3/4 SLP headers. I currently have a 383 with a a cam that operates in the 2400 to 6200 rpm range, stall converter rated at 2500 rpm, TPIS mini ram intake, 52 mm throttle body. I'm not even sure if I would even notice a difference between the two headers. What is you alls opinion?
Thank you
Old Nov 17, 2010 | 02:47 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
Re: help which headers are more appropriate.
1 3/4 is 1 inch of more pipe over 1 5/8.
8 X 1.75 equals 14". 8 X 1.625 equals 13".
all of this is flowing into 6" worth of collectors, which will then go to either 2.5 or 3" exhaust...usually. just a thought. personally, i'd go with which ever fit better.
Old Nov 17, 2010 | 05:19 PM
383RAT's Avatar
Well they fit about equally as well. The 1 3/4 run a bit closer to the brake lines so I may have to wrap them. I'm just wondering if I could get 2 tenths of a second off my quarter mile time if I ran the 1 3/4 vs the 1 5/8. I'm thinking I probably won't see a difference in my quarter mile time with my current engine setup I just want to know what other people think before I drop this motor back in my car. Oh the exhaust goes to single 3 inch before the cat.
Old Nov 17, 2010 | 06:34 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The more cam, the more compression and the better heads the bigger the headers.
And ...the higher RPM's
Old Nov 18, 2010 | 03:37 PM
87350IROC's Avatar
Car: 87' IROC
Cross sectional area is what is important for flow not diameter.
Assuming zero wall thickness:
1 5/8" = 2.07 in^2
1 3/4" = 2.41 in^2
That's 16% more flow potential. That is significant.
Since you own both, I'd use the 1 3/4" You have a health motor.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
