Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Runner dent remover?
Old Jan 30, 2011 | 09:29 PM
smoked72's Avatar
Car: I have many projects
There is a guy on Ebay that sells a chromemoly ball to straighten dents on TPI runners. Has anyone used this or recommend it??
Old Feb 3, 2011 | 08:36 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: Runner dent remover?
Giving this a bump. I'm curious about this also. Got a few dings I would like to smooth out.
Old Feb 3, 2011 | 08:56 PM
txlegaldealer's Avatar
I bought the set a few months back. It is a metal ball that has about 6 smaller wooden ***** that you force in behind the metal ball until it goes all the way through to the other side. I'll try it out this weekend and let you know the results if nobody else responds by then.
Old Feb 3, 2011 | 09:03 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I bought the upgrade which came with steel ***** to remove the dents and a larger one to make stock runners bigger. Worked very good, came with instructions on dvd. It's worth it if you want to keep the stock runners, I used mine half dozen times. Now I run siamesed slp runners.
Old Feb 3, 2011 | 09:16 PM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
works but very time consuming
Old Feb 4, 2011 | 08:23 AM
bjn's Avatar
bjn
It works great. I bought the kit with all metal ***** that makes the runners larger than stock. With this you have to grind out the flanges a little to fit the ball through.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
toronto formula
Sep 10, 2015 07:31 AM
89fast5oh
Sep 8, 2015 09:55 AM
