Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Radiator - American Eagle AE951-AA
Old Jan 7, 2012 | 08:34 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
I bought & installed a 2 row all aluminum direct fit radiator from ebay. nice except annoying sensor prong leak.
I was concerned if my old stock transmission cooling lines would fit. they did.
Attached Thumbnails Radiator - American Eagle AE951-AA-2-core-vs-1   Radiator - American Eagle AE951-AA-leaking-sensor-plug.jpg   Radiator - American Eagle AE951-AA-side-tanks.jpg
Last edited by scooter500; Jan 7, 2012 at 08:36 PM. Reason: added comment about transmission lines
Old Jan 9, 2012 | 05:05 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: Radiator - American Eagle AE951-AA
Repair of low coolant switch worked and driving to work car kept perfect temperature. Check repair at lunch saw another small leaking part just below radiator cap... Time for more Blue RTV... at least the fixes are cheap and easy...
Old Jan 9, 2012 | 08:47 PM
WilliamSilver's Avatar
Are those leaks defects from the manufacture?
Old Jan 9, 2012 | 09:47 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
That radiator looks identical to the Champion radiator.
Old Jan 10, 2012 | 05:32 AM
scooter500's Avatar
Car: 87 Camaro Z-28
yes, nice except for the 3 o rings.
Old Mar 10, 2012 | 02:25 PM
onemanrace's Avatar
Car: 1988 Camaro IROC-Z
On the strength of reviews from here, and other boards, I bought one of these in October.
It arrived in the UK in November, and was fitted on the 10th.
Over the last month, it's been losing coolant - today I think I've tracked down where it's leaking from. Looks like the fins just near between the upper filler neck and trans cooler inlet were wet and dripping. It's a small leak to be sure, but a leak nonetheless.
Also, it's by no means a direct drop in replacement. My garage have had to fit it canted back at a slight angle, chop the top of the shroud to clear the filler neck and weren't able to fit the rubber isolators at all, which means it's an ally rad sitting on the steel support - not the best situation.
All in all, I'd recommend spending a little more.
Edit:
Also, I've never seen or heard the fans cut in, even when the temperature's reached the red line on the dash!
Old Jun 24, 2019 | 06:08 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I understand this is a seven year old thread but it's an issue that these radiators continue to have.
My second American Eagle radiator is now leaking and it's leaking in the same manner my first one leaked which is also the same spot yours is leaking: The junction between the crossover tubes and the side tank. I've reached out to American Eagle and thy agreed to give me a Return Authorization number but all that means is that I can ship it to them on my dime and they will decide if they want to replace it. Not sure if I want to take that $30-40 gamble or just buy a different one...
Old Jun 24, 2019 | 06:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
My research has shown that it is made by Champion but most likely they all come from the same factory and are rebranded.
Old Jun 27, 2024 | 01:35 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Ran across the same issue on a C10 I was working on a while back. They do make a 1/4 flare to M12-1.25 ORB fitting. Sealed right up.
sheachopper
Jul 31, 2019 11:27 AM
meeklay812
Oct 1, 2015 03:46 PM
