Founder performance LCA and panhard bar review
#51
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
Re: Founder performance LCA and panhard bar review
what was the price?
#52
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
I installed mine with the adjustment towards the passenger side thinking it would be a bit more out of the road grime, not sure if that matters.
I called founders for torque specs and they told me 89 Ft.Lbs on both the lcarbs and panhard rod. The drivers side of the panhard rod torqued up but when I got the passenger side near final torque the bolt twisted off! Not going to try the lcarbs until I talk to founders tomorrow. I'm not sure if I got a bad bolt, my torque wrench is wrong, or if I did something wrong. I have built the entire drive train and suspension with that torque wrench and have never broken a bolt during assembly or disassembly. It concerns me that the other panhard bolt could also be over torqued.
#53
Car: 1988 IROC-Z
Engine: 305 tbi
Transmission: automatic
looking to install founders lca and panhard bar i have a 88 stock iroc-z 305 tbi not sure if i should get the adj bars or none adj?? and does the p/h bar need there bracket or just bolt in thanks for your help mike
#54
Car: '82 Camaro z28
Engine: 355 4-bolt
Transmission: t56 out of 95 Z
Axle/Gears: 3.73 disks out of same 95
If you ever plan on lowering the car. get the adjustable. Some say you should get it anyway because the stock setup could be off on your car. It would allow you to recenter it. I have the adjustable, but my car is 2" lower. If it were me with a stock car, I would have still got the adjustable. I would also highly recommend getting their kit with the adjustable control arms. The control arms have a lot more noticeable feel to them. I also added the lower control arm adjustment brackets. I have good power, with the set it is a lot tougher to break my my 285 rear tires loose.Great improvement!
#56
Car: 1988 IROC-Z
Engine: 305 tbi
thanks for your help that sounds like what i'm going to do..now for the moog springs and kyb struts and shocks.......
#57
Car: 1988 IROC-Z
Engine: 305 tbi
does the adjustable s make more noise then the non adjust..
#58
In my case it was hard to tell, but I don't think they were much louder.
I only street cruise my car and take it to the track 3-4 times a year.
I went from boxed stock LCA to the founders unit.
I have a 4" single exhaust, it's loud.
#59
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
I ordered the Rear suspension Kit (Adj LCA, Adj PH) and LCA Relocation Brackets on the 27th.. It hasnt shipped yet, its still "Awaiting Fulfillment". I've heard alot of good things about Founder Performance.. Also heard alot of people if not most saying they've received their stuff within 5days of ordered.. Hopefully nothing wrong has happened
camaro1185
10-26-2015 06:51 AM
