Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Koni's vs. Bilsteins
Old Jan 13, 2001 | 11:59 AM
86Trans Am's Avatar
What are the pros and cons of each, they will be going on my 86, i am looking for all around performance, both for the strip and road?
Anyone have experience with either of the two
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Jan 13, 2001 | 12:03 PM
SeanSullivan's Avatar
I'm using Koni adjustables on the fronts, am very happy with them. At the stiffest setting it is a bit harsh for the road, but on the track they do work great. Am using KYB gas adjust on the rears.
Old Jan 13, 2001 | 05:34 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I have bilsteins and there are some cons
they are expensive and non adjustable.
but
they are the best mono tube shocks you can buy and have a lifetime warranty and generally last for like 10 times longer than most shocks.
I have always wondered what adjustable shocks would do for me but I only would want to be able to set the konis stiffer than the bilsteins I have. however I think that the bilsteins are as stiff if not stiffer than the highest setting on the konis.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
very trick homemade ramair.
http://www.geocities.com/transam617
Old Jan 14, 2001 | 03:13 PM
calroc's Avatar
I have run the same set of Bilsteins since 1987. The lifetime warranty states 99% effiency AFTER 100,000 miles. Mine perform the same as they did when I bought them, and that's on a lowered car. These Bilsteins are not to be confused with the Delco/Bilsteins that were standard equipment on early IROC's. Those were junk.
85 calif. iroc
383/A4
9" rear
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
3.8TransAM
Sep 17, 2015 02:16 PM
