J&M poly ball rear control arms.
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I just installed these last weekend. They feel good, not really sure if they work but I will be autocrossing her on May 13. The idea is to keep both rear wheels flat on the ground. Install was easy. I changed from Hotchkiss control arms so it wasn't a radical change. Any one else running these?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: J&M poly ball rear control arms.
Been using them for some 5yrs or so.They swivel like a heim joint, but no clunk & are not squeaky either.Very pleased with them.Ive used both heim & standard poly bushing before these.
Engine: All 5.7's
Wow, 5 years huh? How often do you grease them, and what do you use when you run out of their special grease? This is the first stuff I've bought from these guys and I'm happy so far.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I lube them whenever i do the front suspension.I use whatever grease is in the gun, mostly graphite type.
eightsixseven
Dec 16, 2024 01:50 PM
NBrehm
Aug 5, 2015 07:57 PM
