Procomp Electronics PC2451 SB Chevy Stock Head Stud Kit 190,000 PSI Steel
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
Hi.
Did any one use it? the price is 24$ + shipping. and they are rated to 190.000 psi same as ARP studs wich cost 200 $ ........
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Procomp Electronics PC2451 SB Chevy Stock Head Stud Kit 190,000 PSI Steel
Material is one thing, manufacturing and QC is another.
If I was slapping a stock rebuild back together and I lost a stock bolt, then yeah I would be tempted to use them if I couldnt find another stock bolt. If I was wanting to put together a good engine with quality fasteners, especially one with high combustion chamber pressures, I would go ARP.
ProComp does not have a reputation of having high quality products.
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i have the procomp sbc heads with there head bolts, valve guides, roller rocker arms, pushrods, and there distributor. havent had an issue yet. all come down to personal preference and $$
Car: 88 IROC
You may not ever have problems with a higher hp build, but the risk increases. Id rather spend the extra on a product that may have 1 failure per 10,000 versus 1 failure in 1,000. I mean hey, in russian roulette, there are 5 winners.........
Car: Trans Am
All clear. I wanted to put them to my 400 with new heads, but i`ll not take the risk, even if they are same quallity than ARP ,(i don`t belive it).
I already got the ARP on Ebay.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
In my opinion, it's smarter to save money by going with a good quality bolt kit vise a stud kit instead of gambling on a cheap stud kit.
theshackle
Mar 5, 2017 06:37 PM
355tpipickup
Aug 25, 2015 12:54 AM
NinjaNife
Aug 23, 2015 11:49 AM
