lsi front brake brackets from flyinbye.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i just finished installing my 2000 camaro front brakes.i used the brackets from flyinbye.the kit included the brackets,bolts,washers,and thread sealer.it didn't come with instructions like most flyinbye products which really pisses me off but worked great.the caliper mount was usable with the kit though i used some fender washers to fine tune it.the caliper had the proper distances from the rotor,same at top and bottom.i had to use lukes site for instructions. http://lukeskaff.com/?page_id=329 The stock brake lines work if you remove them from the mounts and turn them since the third gen calipers screws are turned sideways.you will need the lsi caliper bolts since the third gen bolts are different.the 'help'section bolt is 13912 if you need one.i already had the tap for the upper bolt but had to buy a metric tap for the lower hole.im still fighting leaks so don't ask how they stop.lol
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
