Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
LED Headlights
Old May 28, 2014 | 11:16 AM
  #51
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: LED Headlights
Hows about posting night pictures of driving vs brights and the lamps next to a car with regular bulbs?
Old Jul 24, 2014 | 03:55 PM
  #52
SavageLaw's Avatar
Re: LED Headlights
I would like someone to show (that has the LED conversion or even the LED headlights from BW installed) what the beam pattern is.
Old Feb 5, 2015 | 07:06 PM
  #53
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
Re: LED Headlights
up i wanta see more
Old Feb 5, 2015 | 08:48 PM
  #54
Termn8r's Avatar
Car: 1989 Iroc Z28 Convertible
Engine: V8 5.0 305 TBI
Re: LED Headlights
The previous post I made, those are the $90 (4 headlights with halos) from Ebay (search for 4x6 halo) I loved them for a while, however, they sure seem less intense than they were when I purchased them. They still work but the intensity of them seems about half of what they were when I purchased them a year ago. I suppose it could be some of the brighter led's I have now.
My goal this year is to take a set like these and take them apart and put in SMD led's that are addressable. I found the led's I plan on purchasing, just have to find the time to do it!
Old Feb 6, 2015 | 01:46 PM
  #55
z28_87Camaro's Avatar
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
Re: LED Headlights
I have the JW Speaker LED's in my Kenworth. Well worth the money! However, a little pricey @ $300/light to put in the Camaro.
Old Feb 8, 2015 | 08:27 PM
  #56
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: LED Headlights
Got a link?
Old Feb 8, 2015 | 09:15 PM
  #57
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: LED Headlights
Those JW Speaker headlights are 4x6 that fit Camaros. The JW Speaker 5x7/7x6 that fits Firebirds is linked in posts #44 and #45 of this thread. Firechicken has them, and he has a video here on TGO showing them.
Old Feb 8, 2015 | 10:43 PM
  #58
Re: LED Headlights
Here's a link to the 4x6 JW's.
I don't know where you guys can get them apart from ordering them online.
I'm in Alberta, Canada and we can buy them at most truck supply stores as a lot of us travel in the bush for oilfield work.
Costs us about $1300 for a full set.
Old Feb 9, 2015 | 03:12 PM
  #59
KITT1983's Avatar
Re: LED Headlights
http://www.jwspeaker.com/products/he...product=500493
http://www.jwspeaker.com/products/he...-low-headlight
Old Feb 12, 2015 | 11:23 AM
  #60
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Re: LED Headlights
I have like $8 Sylvania head lights aimed properly and they work extremely well. Those JW units look very nice but at that price do you have to worry about getting the European one that are pointed the wrong way?
Old Feb 12, 2015 | 12:54 PM
  #61
Tibo's Avatar
Car: 1991 Z28 Vert
Re: LED Headlights
Opinions on the stock style headlights are relative. If you drive in city mainly, they work great. If you drive on highways outside of cities they are poor to fair. If you drive on rural roads they are useless in anything but bright mode. If you compare them to newer lights they are poor and to hid lights it is a huge difference. Go from a car with hid lights to your car and you will think your headlights aren't even on. You can upgrade stock lights to the silver stars by Sylvania but the filaments always burned out faster for me.
Old Feb 12, 2015 | 02:05 PM
  #62
91ls1t56's Avatar
Car: 91 Z28
Re: LED Headlights
Proper aiming of the lights is the key. I can not argue the point that modern lights are brighter. If that modern bright light is not aimed properly you still will not see any better. I drive a lot to and from all types of places ranging from the middle of nowhere to the city. I use my hi beams as much as traffic will allow and this is in my 04 3/4 ton truck with more modern lighting. A friend of mine had the opportunity to drive my camaro when dark and commented on how well he was able to see.
Old Feb 12, 2015 | 07:08 PM
  #63
WTR388's Avatar
Car: 87 Trans Am
Re: LED Headlights
I also have no real complaints about my headlights, I'm assuming that whoever put the current pair in bought some good ones (still sealed beam). It's darn close to my 2012 ram with silverstars, which surprised me as I expected them to suck. I will be putting some LED lights in once everything else has been taken care of.
Old Apr 13, 2015 | 06:58 AM
  #64
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Re: LED Headlights
Alternately you could just buy a set of Projectors from Skinny Boy Lighting and get the same if not better results.
Old Jun 4, 2015 | 05:48 PM
  #65
Red_Dragon's Avatar
Car: 1988 Iroc-Z
Re: LED Headlights
I've had my custom JW Speaker headlights on my camaro for a year or two now. Best lights I've ever had on a vehicle, great for night driving and they look cool. Helps knowing someone who works at JW!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
