Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
2 Way Difff?!?!
Old Jul 6, 2014 | 02:05 AM
Hoonigan's Avatar
Car: 1986 Iroc Z28
Transmission: 5 speed
Axle/Gears: Stock
2 Way Difff?!?!
Hey guys, well im building a full drift track car with my 86 Z28, I dont necessarily want to weld my diff to get it to slide them corners better. I cant find a 2 way differential / locker. If someone has a link or a brand name let me know!
Old Jul 6, 2014 | 10:50 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 2 Way Difff?!?!
Detroit trutrac or detroit locker. If you planning to use the stock 10 bolt or 9 bolt, forget it they wont last long
Old Jul 6, 2014 | 10:52 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: 2 Way Difff?!?!
An ARB Air Locker would be nice. They are popular in the off-road world. Conventional differential, which can be 100% locked with air pressure.
Unfortunately, they're focus is off-roading, this no 7.6" application. But, if you were planning to build a stronger rear axle anyway, then one of these might be an option, depending on what axle you choose to build.
http://store.arbusa.com/Air-Lockers-C7.aspx
There are electric lockers in the production car world, but I'm not sure if they are in the aftermarket or not.
Old Jul 6, 2014 | 07:52 PM
Hoonigan's Avatar
Car: 1986 Iroc Z28
Axle/Gears: Stock
Re: 2 Way Difff?!?!
What wont last long the locker or rear end?
Old Jul 6, 2014 | 08:20 PM
project89's Avatar
Re: 2 Way Difff?!?!
just use a mini spool
Old Jul 7, 2014 | 12:54 AM
Hoonigan's Avatar
Car: 1986 Iroc Z28
Axle/Gears: Stock
Re: 2 Way Difff?!?!
Wow these are a great price. It keeps the diff constantly locked?
I also found a guy with a locker for my car for the same price as one as those, might pick it up Monday
Old Jul 7, 2014 | 03:13 AM
project89's Avatar
Re: 2 Way Difff?!?!
yes its always locked , if its a mini locker dont waste ur money it will break under the stresses of drifting.
with the minispool it will be hard on the axles during normal street driving , but they are so easy to install that u could drive to the drift event pop the rear cover off install the mini spool in about 30 mins. then after the event u can put the normal spider gears back in in the same amount of time
i had one in my v6 turbo car till i finally said hell with it and welded the open diff , car was a daily driver and id have to replace the axles every year to 2 years as id a;lways twist them up
yankeecarman
Dec 10, 2012 12:53 PM
