Top Down Solutions steering brace
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Top Down Solutions steering brace
The 3rd bolt is very nice to have when installing these. You can bolt it to the car without having to hold the swaybar in place at the same time. I run these on all of the cars that can use an aftermarket one.
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Transmission: Pro-built 700R4
I have one of the TDS wonderbars on both of my cars, which both have dual fans, and I have not had any clearance issues.
the UMI unit fits also(its a nice piece..thats why I have one)..its less then a pound heavier (10oz)I'm dropping as much weight as I can with things I can..without chopping the car up to a tin can..no cutting! keeping it as strong as I can..
Nice ok TDS bar it is!! that third bolt location is awesome as well
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I have the TDS bar and I did have to trim my factory single fan shroud slightly at the very bottom with my dremel. Otherwise the fit is perfect. When I swapped to the TPI dual fan set up, zero issues. When I later installed the LS fan swap, also no issues. After 10 years I need to have it re-coated but otherwise its held up very well.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
does it interfere with certain swaybars ? such as UMI
Car: 1984 Trans Am
It shouldn't. I have Hotchkiss sway bars and it didn't interfere with them.
