OBD2 Scanner, Need help picking out a good all around option.
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, I need to update my OBD2 Scanner, I am looking for a good all-around option that will allow me to Diagnose, Read/Clear Codes, ABS and Elec E Brake work and so on. I Would like to stay around or below the $200 Range and Don't really want the Bluetooth/Phone models. I would like to be able to use it on Foreign and Domestic vehicles. Thank you
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: OBD2 Scanner, Need help picking out a good all around option.
Look at autel scanners good bang for the buck on amazon
Car: 86 Z28
Axle/Gears: 10 Bolt 2.73 Open
They lost me at this opening statement:
"Top preset choice for your father, husband, brother or boyfriend.EVERY CAR OWNER WILL NEED IT! It comes with high-quality case with rugged and handy design.Get NT624 Elite full system scan tool and give your lover a surprise!"
Car: 86 Z28
I went with the Innova 5610, It seems like it will do a lot, To get a true Bidirectional scanner I would have to spend quite a bit more.
Car: 90 Formula / T-tops
Transmission: MD8
just in case anyone is reading this for options, I'm using Foxwell 510 Elite for my BMW's and Toyota's. Have had good luck with it. Doesn't really do any programming tho.
