Need help with a 96 Berretta
Old Jun 16, 2003 | 10:29 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Hey guys, I need some help with a 96 Berretta that I am looking to buy for a commuter. The owner said that the service engine light is on, and I was wondering if I could pull the codes like we can with our third gens. If so, how do you do it? Or is it OBD-II and I have to find someone with a scanner? Any help appreciated.
Old Jun 17, 2003 | 03:52 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Sure: 96 is OBD II. I don't know more.
Old Jun 18, 2003 | 08:36 AM
RustBucket's Avatar
Swing by Autozone they'll pull the codes for you. Take the car for a "Test Drive" and stop in. They've got an OBDII scanner and as long as the store's not packed, they're more than happy to pull the codes for you.
Old Jun 18, 2003 | 02:48 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Sounds like a good idea! Thanks!
Old Jun 18, 2003 | 10:55 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
yeah it's obd-ii, mine is a late 94, listed as a 95 and has obd 1
Old Jun 19, 2003 | 12:35 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I am looking at a 96 Z26 myself. Being a Berretta owner yourself have you had any problems with the car? Is there any thing I should look out for when I go to look at it? As you can see I hate buying used cars. I had a bad experience once and I do not want to end up with a car that I have to put a lot of money into.
Old Jun 19, 2003 | 03:35 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
well i had a warranty with mine, but not too many problems, 1 thing is the lower control arms/bushings wear out, check those, and i've heard stories about the intake gaskets leaking and i did have to have that done, those were the only major things i had done on my car, aside from normal wear and tear stuff, any other questions just ask
Old Jun 19, 2003 | 05:18 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Thanks for the advice! Just out of curiosity how many miles are on you Beretta?
Old Jun 19, 2003 | 08:02 PM
Dracul's Avatar
Car: 1983 Camaro z28
Engine: 5.7
Transmission: 5spd
you might wanna check the beretta.net msg board and another thing to watch out for is water leaks. i'm fighting a nasty one right now which i think is actually a clogged hose for my a/c somehow putting the water that would normally just drip to the ground into my driver side carpet.
Old Jun 19, 2003 | 08:33 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
mine has 139k miles on it, and i've never had any leaks inside except for when i broke a grommet on the firewall to run my amp wire through.
Old Jun 19, 2003 | 11:07 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Hey guys thanks for the info! Your work here is done.
Old Jun 21, 2003 | 09:02 AM
Vader's Avatar
Remember, threads are suppsed to be ThirdGen related or of general interest to ThirdGen owners/operators.
lilwill355
Dec 17, 2008 03:01 PM
ChevyRS-305
Nov 16, 2007 10:08 AM
f_body_4_life
Theoretical and Street Racing
74
Dec 31, 2006 02:21 PM
'91TealRS
Aug 2, 2006 09:21 PM
EmoDork138
Mar 29, 2006 11:16 PM
