Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Accel 300+ ignition?
Old Feb 4, 2001 | 08:27 AM
smithtc's Avatar
Anyone use this product, and what are your thoughts on its value?
Gunmetal 89GTA T-Tops L98
Gettin there's all the fun
Best 60 ft: 1.996'
Best 1/8th mile: 9.12 @ 76mph
Mods: air filter, hypertech chip, 3" exhaust
Old Feb 4, 2001 | 04:23 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Ive had it in my car for the last 5 years. Not a single problem yet! I like it cause its the smallest box on the market, plus it comes with a wireing harness to plug into your factory harness. Very easy to install. All you need is a ground.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.52/1.6 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, 3.23 rear gears, white face gagues, and NOS!
When I get back from Kosovo I will be installing these on-order items!
Old Feb 4, 2001 | 06:14 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I'v been running one for over a year and I'm vary happy with it,
Old Feb 4, 2001 | 10:32 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
seems like a good buy.
I would like to add that my car ran very well without it but I plan to get n20 and figured it would be good insurance to get the most out of the "juice"
btw I was able to gap my plugs to .06 in.
hows that for voltage!!
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
http://www.geocities.com/transam617
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
efiguy
Sep 27, 2015 01:30 PM
