What radiator fan can I adapt?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: What radiator fan can I adapt?
If it is original fan,probably something else wrong with the cooling system-as basicly the same fan was used on 350 C4 Corvettes and non-AC 3rd and 4th gen 350s through '97,so plenty for a v6. '90-95 Taurus 3.8 used to be a common upgrade fan,but those are getting back in the past pretty good now...
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
LS1 fans are popular. I used corolla dual fans
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
https://www.thirdgen.org/forums/cool...onversion.html
Likely overkill for a V6...I would just get a factory replacement fan. It has worked fine for 34 years right?
