Accel 300+ ignition??
Car: 1989 formula 350
Engine: tpi 350
Transmission: th700r4
I bought an accel 300+ ignition off ebay a while back. When i Recieved it I was missing some off the wiring harness. I was wondering if anyone could tell me how to hard wire it directly without the harness?? It came without the coil. Does that matter.
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
You are supposed to use an aftermarket high output coil like the Crane 91/92 coil or MSD coil. If I can find my instruction I'll e-mail you a copy.
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Re: Accel 300+ ignition??
here is a diagram
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
The 300+ is what Lingenfeter installed in my car. back in 93. still have all the info with the part boxes.
with this nexed upgrade going all new MSD.
everything they installed was bolt in plug and play. this will all be up for grabs in a few weeks... i had all new parts swapped OUT in 2003 under there life time warrenty.. the car set for 10 years after that.
they no longer do the lifetime warrenty..to bad..
there parts worked Fantastic.. would keep them.. but they no longer make anything forthe cars 20 years old..so going with MSD
edit to add..ya they still make stuff for the older cars...but it's not cutting edg
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
efiguy
Sep 27, 2015 01:30 PM
