Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Gears
Old Feb 25, 2002 | 08:54 PM
Druo-Z28's Avatar
Gears
I have a 87 camaro with 350 tpi and i am looking into changing my gears. I have a 2.73 limited slip rear end in it now with disk brakes.
Does anyone know a good brand of gears? im guessing i have a 2 series carrier and i want to put 3.73s in it. Has anyone done this change befor and how did it work out?
Old Feb 25, 2002 | 09:09 PM
Druo-Z28's Avatar
anyone?
Old Feb 25, 2002 | 09:51 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Richmond are good.
Yes, you have a 2 series carrier. 3.73's might be a little steep for a stock 350 TPI, 3.42's might suit the engine better.
Old Feb 25, 2002 | 10:01 PM
Druo-Z28's Avatar
what should be done so that it could handle 3.73s
Old Feb 25, 2002 | 11:54 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
There are far better people in the know on this board, but I did a lot of research before going from 2.73's to 3.42's. The one thing I got a ton of opinions on were that the Richmond gears make a lot of noise. Most recommended US/Strange and Motive. I ended up buying GM 3.42's.
Further, the majority voted on 3.42's on a 350 TPI with 700R4, but there were some who swore by 3.73's.
Obviously you need to get the 3 series carrier if you go with the 3.42's or 3.73's, whichever you choose.
Oh yeah, and my application is with 350 TPI and 700R4 that I swapped in, not the original TBI 305.
Good Luck, and I'm sure others will share their information.
Old Mar 3, 2002 | 05:36 PM
Pete92TA's Avatar
heard the same thing richmond wine and GM motives are quiet if done right. I am going to do the same mod hopefully this spring. Probally go 342also.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
