Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Rim Screws
Old Feb 13, 2001 | 06:35 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Rim Screws
Who uses them and at what HP should I consider using them? I am talking about the screws that are used to mount a slick to a rim.
Steve
Old Feb 14, 2001 | 03:03 PM
JeffT's Avatar
Car: 1991 Z28
Mark your wheel/tire, make a pass and check out the marks. If they are not lined up then you are ready for screws.
Old Feb 25, 2001 | 06:24 PM
9.0L Firebird's Avatar
Both Moroso and Mr. Gasket sell rim screws. don't use regular sheet metal screws, the heads will strip/break off when installing. if you are running low pressure in your slicks (below 10 lbs) or using tubes, you will need screws when you reach a 1.40 60' time (about a low 12 sec qtr). if you are tubeless, mark the tire position in relation to the valve with a wide shoe polish stripe and watch for turning the tire on the rim. if it isn't turning, you don't need screws.
Old Feb 26, 2001 | 11:33 PM
Superblue87Formula's Avatar
how do you put the screws in w/out popping your tubes?
Old Feb 27, 2001 | 06:04 PM
ede's Avatar
ede
SB the screws aren't long enough to go through the bead, just hold it.
ICON Motorsports
1st & 3rd
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
3rd gen money
Oct 11, 2019 09:57 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
LT1Formula
Oct 8, 2015 08:34 PM
