Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Difference's between trick flow G2 & 23degree heads?
Old Mar 5, 2002 | 08:15 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
anyone know? which is better?
Old Mar 6, 2002 | 08:52 AM
Lounge Lizard 6's Avatar
Out of the box I believe the G2s have a little more flow. Physically the intake valve angle on the G2 is canted ~16° and the chamber "twisted" around bringing the intake a little more over the cylinder.
Between those two heads I wouldn't even hesitate, their 23° head is the only way.
Old Mar 9, 2002 | 05:16 PM
LilJayV10's Avatar
Engine: 406 Roller
anyone else? any flow numbers or anything?
Old Mar 12, 2002 | 02:41 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I would go the other route with the G2s (if i wasn't an AFR owner).
All the literature I've seen and guys I've talked to say the G1/G2s substantially outperform the 23*. There have been problems with valve guides and stuff with the early models the G1s, but supposedly the G2s have solved that.
I have seen more than enough twisted wedge cars in the mid to low 12s at 110+ and not one 23* car in the 12s at all or with a decent trap speed.
this is just my observation, and anyone feel free to prove me wrong.
I think part of it is that not many people run the 23* yet, and the TW heads are already established.
Old Mar 12, 2002 | 06:48 PM
mcconahay37's Avatar
Well, I went with the 23*heads. I need to save all the money i can, and I've heard nothing but good about them, so I'll see if it's the truth when I finally get my engine built and installed.
Old Mar 12, 2002 | 07:25 PM
LilJayV10's Avatar
Engine: 406 Roller
arent the g2 heads canted? in my opinon thats a good idea to unshroud the valves and get more air into the cylinder. but i dont know anything about the 23 heads.
Old Mar 13, 2002 | 12:19 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I should've been in the 12's last year, but I couldn't do a good burnout or hook up off the line due to the crappy Torsen diff. I will be in the 12's this spring, hopefully this Friday if I get my new diff installed by then. I was hitting 105 mph with a restrictive muffler and poor tuning (spark/fuel) and half-ported SLP runners (still haven't finished them yet), so I'll be laying down some good numbers this year. In CHP's cylinder head testing, the 23* heads flowed almost as good as the G2's and were just about even with the AFR's, although airflow isn't everything when it comes to making power.
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
69GTOby
Apr 18, 2016 02:34 PM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
