Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Replacement coil??
Old Apr 2, 2002 | 01:06 PM
Snowracer's Avatar
Replacement coil??
Does anyone make a replacement coil for 5.7 TPI motor's that mount's in the stock location?Manufacturer/PN's?
I ordered some new plug wires and figured that I might as well replace the coil at the same time as part of the tune-up.
Thank's in advance SR
Old Apr 2, 2002 | 01:46 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Accel, MSD, and Mallory, to name a few....
Check your Jeg's or Summit catalogs in the distributor section for 'HEI Replacement Coils'
They should be about $30-$50
Old Apr 4, 2002 | 11:45 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
i have a accell cost me about 50.00 works great no complants. The hardest part of the install was drilling the rivits out on the old coil. Wasnt to bad though
Old Apr 6, 2002 | 03:15 PM
Drew ATX's Avatar
You don't have the type with the coil in cap do you? If you do I got the Hypertech coil for mine and holy crap. It is bad ***. My friend put one on his '90 Vette also and he got good results from his too. If that's the type you have, I say go Hypertech all the way.
Old Apr 9, 2002 | 04:52 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I loved my MSD Blaster Coil. Easy install and like the other guy said, hardest part was knocking out the old rivets but that wasn't even hard. Good little mod and step towards upgrading ur ignition.
Old Apr 13, 2002 | 05:17 AM
willdog666's Avatar
Car: 1988 camaro sc
Engine: 350 tbi swap
Axle/Gears: posi 3:23 swap
i also used msd blaster coil, helped a little, downshifts better now and a fraction more responsive.......cheap mod worth it, can't hurt right?
92camaroJoe
Jul 29, 2023 07:57 PM
TheExaminer
Aug 25, 2015 07:34 PM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
