Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
Trickflow, Summit
Old May 22, 2011 | 07:37 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Trickflow, Summit
Having trouble setting up my valve train, specifically push rod length, on my build. Called tech at both places, (bought the heads at Summit). TF wasn't very helpful and seemed like he was in a hurry. The guy at Summit, (Tom), was on the phone with me for 15 minutes gave me literally like 6 different things to try before I get different rocker arms. So, while I can't yet comment on the heads themselves, Summit gets a big thumbs up from me!
Old May 22, 2011 | 08:25 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Trickflow, Summit
you need a pushrod length checker? you set it up. and then order the right length. most times for a stock SBC with stamped rockers and an aftermarket aluminum head you need 7.900 inch long pushrods. But REALLY every engine should have custom length rockers.
Old May 24, 2011 | 01:06 AM
watajob's Avatar
Car: 92 T/A 'vert
Got one. But, for some reason, it's showing a stick way shorter than stock, which is kinda' weird. I've a got a few more things I want to try. If they don't work, rest assured, I'll be on here begging for help!
Old May 24, 2011 | 04:02 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I had to use 6.850" pushrods http://www.summitracing.com/parts/CCA-7633-16/, with 1.5 Scorpion Performance roller rockers http://www.summitracing.com/parts/SCC-SCP1037BL/ and summitracing 170 cylinderheads http://www.summitracing.com/parts/SUM-162108/
Old May 24, 2011 | 09:35 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Dont you basically center out the adjuster int he rocker arm? and make sure your roller tip is centered and then thread the pushrod length checker out and there ya go...am i wrong?
Old May 25, 2011 | 03:53 AM
thomas1976's Avatar
Car: 91 Trans am
http://www.compcams.com/Pages/417/va...-geometry.aspx
http://www.carcraft.com/techarticles...gth/index.html
I also replaced the valve springs with very soft springs, for the mesurment, found them in a harware shop.
Hotrodboba400
Dec 10, 2019 07:07 PM
69GTOby
Apr 18, 2016 02:34 PM
school boy
Oct 22, 2015 11:47 AM
randy210
Oct 15, 2015 03:43 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
