Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
Founders Proformance..
Old Jun 4, 2012 | 02:17 PM
moedaman's Avatar
Well i bought Caster/chamber plates and rear relocation brackets from them and the only issue i had (and not really a issue) was they had to wait for powder coat..The price was right shipping charges was decent and HONESTY... about why my parts were not shipped shortly after my order was placed is why i will be a repeat customer.The packing of my parts was top notch! The only small blemish was on the rear relocation bracket where it was probly hung up for powder coat..So no complaints and would recommend Founders to fellow Thirdgen owners..I do wish they made more parts for our cars..
Old Jun 4, 2012 | 03:40 PM
pg29's Avatar
Car: 88 GTA
Re: Founders Proformance..
do you know how much camber and caster can be adjusted? Do you have numbers as to the maximum amounts of negative camber and caster that can be dialed in or out? Thanks.
Old Jun 5, 2012 | 08:44 AM
moedaman's Avatar
No info on that but I will be looking into that..sorry..
Old Jun 15, 2012 | 03:55 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I installed the c/c plates and had no issues at all adjusting my caster or camber to drag specs. My strut tower sheet metal bent before their plates did.
Old Aug 24, 2012 | 04:24 AM
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
mine worked great as well. founders has great quality parts for cheap prices.
Old Aug 26, 2012 | 08:48 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
The founder caster camber plates will allow you to get the correct setting if you have lowered your car and couldnt get enough from the stock ones. Like everyone else has comented on so many times before, they are very good quality at an affordible price. I currently am running there C/C plates, relocation brackets, dbl adj Lower control arms with spherical rod ends on both ends
J-money
Jan 4, 2019 09:45 AM
Veaceonee
Sep 29, 2016 08:15 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
