Proform Cust. Service
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I know Proform isn't one of the big names in engine parts, but I bought a roller rocker set from them for the engine I put in my Camaro. Just the other day on the way home from work I dropped a cylinder. Investigation revealed that the intake rocker on #1 broke. I had about 60 miles on this engine. I called them today to see if they would replace it. They didn't question where I bought this from, how long I had them, nothing. They asked that I return the broken one, and they will send me 2 new ones. I wish every company had service like this.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust,Dynomax Bullet Mufflers, T&R Motorsports custom air intake
Joshua Johnston
1991 Z-28
Transmission: 4L80E/4L80E
Perhaps you should try to talk them out of a full set, just to have on hand as they break on you over the next year.
Before ordering parts for my build-up, I asked Competition Products about those rockers (their catalog says something to the effect of "warranted against breakage only for one year", and calls them "Imported Roller Rockers"). Basically, they said don't use them on anything other than a standard lift cam with standard type valve springs.
I ended up getting roller-tip stamped elongated slot rockers, just to keep the cost down. CP said that was better than going with the Proform rollers with the ZZ3 cam and the springs I am getting. They sacrificed about $50 in sales to give me that advice. That give you any clues?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
