Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
suspension Question? Please help!!
Old Nov 13, 2001 | 08:21 AM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I am looking to lower my car about an inch or so. I was looking at the Hotchkis and Eibach lowering springs. Which springs are the better one to go with? Also all that has to be done is to replace the springs w/ the lowering springs? Right? Is it really that easy to lower your car and inch? Well thanks in advance for any help.
Old Nov 13, 2001 | 08:39 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by 85maroz28:
I am looking to lower my car about an inch or so. I was looking at the Hotchkis and Eibach lowering springs. Which springs are the better one to go with? Also all that has to be done is to replace the springs w/ the lowering springs? Right? Is it really that easy to lower your car and inch? Well thanks in advance for any help.</font>
this should be in the suspension section but,
both are fine. yes that's all you need to do to lower your car 1". but, get an alignment afterwards because it changes the camber.
Old Nov 13, 2001 | 08:42 PM
85maroz28's Avatar
Thanks feel free to reply!!
Old Dec 3, 2001 | 10:53 PM
harvtherabbit's Avatar
the new issue of CAR CRAFT mag. has an artical on this they have a 3rd gen they r using as a project car cheack it out very informative
Old Dec 3, 2001 | 11:24 PM
cort351w's Avatar
Use quality drop spindles unless you want to wear your tires out in very little time. Alternatively, go with the drop springs and use a castor/camber kit to restore the geometry.
lt1z350
Aug 28, 2015 05:57 AM
cam-mike
Aug 24, 2015 07:23 AM
redmaroz
Aug 16, 2015 11:40 PM
