Ignition coil keeps frying. Plus code 42 350 tpi
Car: 85 iroc
Engine: 350 tpi dropped in
I've looked up several threads and can't seem to get a conclusive answer. What could cause that
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ignition coil keeps frying. Plus code 42 350 tpi
Plug gap ? Wires ohmed out ?
Car: 85 iroc
Could a bad distributor or icm or combination of both cause it. Just got it running and was doing good then this code popped up then as I was driving it died and then I saw the ignition coil fry.
