Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Superram Bracket Not Lining UP!!
Old Apr 15, 2005 | 01:37 AM
moneyman380's Avatar
Car: 1991 Z28
I tried the stock bracket and it didnt work, so i ordered a accel bracket and it doesnt line up with the holes at all. WTF! I spent $30 bucks on a paper weight!
Old Apr 15, 2005 | 09:58 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
see my other post in my thread....it does line up just bolt it directly to the SR, not to that silly mounting plate in your picture...the bracket shoulld attach directly to the SR
Old Apr 15, 2005 | 11:36 AM
Car: 1991 Z28
still dont understand how it bolts up, also the bracket is my offset for my plate NOS which i needed for my tpi so shouldnt i need it for my superram.
Old Apr 15, 2005 | 11:40 AM
Car: 1987 GTA
did you know that the SR throttle and TV bracket is different than stock?
Old Apr 15, 2005 | 12:40 PM
Car: 1991 Z28
yes thats why i order the one in the pic from jegs, they said it was the superram bracket. But the holes dont line up on the superram intake. You cant even get two holes lined up
Old Apr 15, 2005 | 12:54 PM
Car: 1987 GTA
hmmn, maybe they sent you the stock one...check it to your stock one. is it the same? I'd really have to look at it closely to see if you could fbricate it...maybe you could make a mounting plate to accept it? weld the bracket to a piece of metal, and then drill the correctly spaced holes in the new piece of metal (but the barcket may still not have the right angle,...but you could probably rotate it to account for that too.....any shop can weld it for you , just keep it a tinner gauge, so it doesn't change the distance from the upper plenumm much
Old Apr 15, 2005 | 10:10 PM
88blackgta's Avatar
Car: 88 GTA Notchback
Engine: 355
The bracket Jegs sent you is for the LT1 SuperRam. The LT1 SuperRam plenum is 5/8" shorter which necessitates the holes and the bracket being different. Same thing happened to me. I checked with Accel, they told me what I had received. I called Jegs and told them what Accel had told me and they then sent me the correct bracket. Major hassle because of Jegs screw up.
Old Apr 16, 2005 | 12:08 AM
Car: 1991 Z28
looks like jegs is getting it back, thanks for the help
Old Apr 16, 2005 | 09:03 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Is that the one I sent you? Doesnt work?
Old Apr 16, 2005 | 10:25 PM
Car: 1991 Z28
no yours fit perfect, thanks again. Jegs sent me the one in the pic a week earlier than expected, which turns out to be a lt1 superram bracket. I got the one from jegs thursday and then got yours friday, (thank ***, i was about to kill someone after the jegs one didnt fit) I was planning on canceling the jegs order after i got yours, but it came early. (da@it)
Old Apr 20, 2005 | 01:11 AM
Car: 1991 Z28
Got it all together, but the transmission still wont shift right. Still wondering if the nos offset bracket is throwing off the bracket alignment. The nos bracket is the silver piece in the pic, which pushes the throttle bracket closer to the TB.
Old Apr 20, 2005 | 09:02 PM
onebinky's Avatar
Just out of curiosity, did you reset the TV cable after you got it all together?
Old Apr 20, 2005 | 10:43 PM
Car: 1991 Z28
i reset it several times and still no luck
Old Apr 20, 2005 | 11:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I accually had to drill out the holes more on my other bracket so I Could play around with the geometry
Old Apr 20, 2005 | 11:18 PM
Car: 1987 GTA
i didn't reset the cable,...what is the procedure to do that?
Old Apr 20, 2005 | 11:54 PM
onebinky's Avatar
There is a plastic sleeve on the TV cable end. There is also a "D" shaped metal button on the cable end. Push the "D" shaped metal piece in, and then slide the plastic sleeve all the way back into the housing. Most cables the button is very hard to press, just so you expect that. Then go into the car, and press the pedal down to the floor. You should hear a ratcheting noise as the cable readjusts itself. As long as the teeth on the plastic sleeve are not worn out, the adjustment will hold and your job is done.
Old Apr 21, 2005 | 12:02 AM
Car: 1987 GTA
so you slide the plastic part witht the teeth on it all the way nto the housing, so it dissapears and all you see is cable and then the "D" shaped button? thanks alot!
Old Apr 21, 2005 | 12:41 AM
onebinky's Avatar
yep, thats all there is to it
Old Apr 21, 2005 | 09:38 AM
Car: 1987 GTA
thanks! -J
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
