Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Fuel Lines For Holley Stealth Ram
Old Apr 20, 2005 | 02:12 PM
87TAWS6's Avatar
Car: 1979 Firebird Esprit Redbird, 1987 Trans Am WS6
Engine: 301ci, 305ci
Transmission: T/H350, 700R4
A guy from work told me that with my new holley stealth ram for my TPI motor, i need to get new braided fuel lines. Do you guys know what size the AN fittings are, and how long they need to be? Any help from someone whos done this before would be great.
Old Apr 21, 2005 | 07:59 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
The fittings are -6 AN, and the length of the lines depends on how you route them.
Try a search, this is a popular topic.
Old Apr 22, 2005 | 04:42 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i ran new braided lines all the way to the tank.
Old Apr 25, 2005 | 07:23 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Do they really need to be braided? Stock they aren't, and I'm sure you could get a set made for cheaper if you don't go with braided lines. $120 is kind of much for fuel lines.
Hell, I'm pretty sure you could buy the hose and connectors from summit for cheaper than that. More like $60 to $80 total.
Old Apr 25, 2005 | 09:09 PM
Z69's Avatar
Z69
I'm sure there are other ways to do this.
And it's been about 10 years since I looked at a 3rd gen fuel line.
Aeroquip has a Versaflare product line.
Basically you cut your rubber lines off the stock steel lines and slip them on and tighten them up. Rated to 1000psi or so.
So you end up with a #6 male AN end on your steel lines.
The HSR comes with #6 fittings, so you just buy the appropriate length of hose and 4 hose ends and hook them up.
I think the stock return line is a 5/16 line. Which is a #5 size.
Not very common size. Not sure if there is a #5 to #6 AN fitting.
Have you checked Stealthram.com to see if it has any info. Your not the first one to do this.
You can usually get Aeroquip at a Hydraulic shop.
If you need to go back to stock rails, Russell and Accel sell adapters for the stock rails to #6 AN hose for about $15 ea.
oh
For AN lines sizing, the # is equal to the number of 16ths. So 5/16 is #5, 3/8=6/16=#6, #8 is 8/16. Also, the fitting ID isn't acually the listed size. A #8 fitting for example has a 7/16 ID, but fits a 1/2 or #8 hose. Only matters if your close to the accepatable flow limit for that size line. #8 at EFI pressures is good to 800-900 hp.
Old Apr 25, 2005 | 09:40 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
No need to cut anything. You can unscrew the rubber lines from the steel ones, and Earls makes an adapter to adapt both the feed and return lines to -6AN.
Old Apr 26, 2005 | 12:01 AM
smokefan's Avatar
i had a carb on mine and the old fuel lines ran on the passenger side. since i had everything out of the car (meaning motor and tranny) i figured it was just as easy to install new lines so that is why i went with bradied lines. by all means you dont have to go with the bradied lines. go to stealthram.com andsee how they show the lines run
Old May 4, 2005 | 03:42 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I'm running plain old rubber high pressure fuel injection hose with the barb fittings supplied for the Stealth Ram. The hoses run down to metal lines on the passenger side frame rail. Maybe some day I'll spring for some fancy braided hoses with threaded fittings on the ends, but for now this still looks clean and is plenty safe.
Old May 4, 2005 | 04:34 PM
smokefan's Avatar
i was going to go that route with the high pressure rubber lines and than one day change over to braided but than i just said forget it and did the braided instead. both ways work just fine
Old May 4, 2005 | 04:35 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I did this too. $80 and I had custom SS braided back to the filter/tank. Easy as hell. Alot easier IMO than flaring the stock lines and cleaner than runing adapters from the stock lines down the frame rail.
Old May 9, 2005 | 09:30 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I just cut my lines where they made the upward angle under the car by the engine bay. I bought some of those compression fittings from Earl's that are -6AN on the ends. Then i fabricated 2 -6 braided hoses to run up to the S/R fittings. Very clean install once i was done. The fittings were only like $15-$20 if i remember.
Old May 9, 2005 | 11:12 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 3.73
What size were the original fittings at the end of the rubber lines?
Old May 9, 2005 | 11:39 PM
crazygearhead's Avatar
i have been looking for that answer too.. i just got the HSR and i am trying to figgure out what i need. i found this http://www.holley.com/HiOctn/ProdLin...A/9894DBH.html
but i am not sure if that is what i am looking for.
Old May 11, 2005 | 03:10 AM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
I have another question pertaining to the HSR. There were a decent amount of hoses that came from the stock TPI but the HSR does not have provisions for most of these. Did all of you just plug them and not worry about it or did you somehow mount them?
Old May 11, 2005 | 10:26 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
There's only a few that you really need, brake booster, fuel pressure regulator, pcv, and HVAC controls. I just grabbed some barb fittings from ace.
Old May 12, 2005 | 08:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
They are the correct fittings for the stock lines off of the frame rail. Need one 14mm (return line) and one 16mm (feed line) fitting.
RBob.
Old May 12, 2005 | 06:19 PM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Where does the FPR hook up to? I have an AFPR on my HSR and it has a screw in place of a fitting. Do you mean reference hose for the AFPR guage? Also, what are the HVAC controls? Do you mean MAP sensor?
Old May 12, 2005 | 11:44 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I just mean the hose that goes over top of that screw. You're supposed to have a hose that goes to the intake so the pressure varies with vacuum.
By HVAC controls I mean the heater controls for inside the car. There are two hard plastic tubes that come from the wiring harness just alittle bit off center near where the coil is stock. One goes to something (I have no idea, I don't have that connected) and the other goes to the HVAC controls inside the car.
If yours is Speed Density then it'll need a MAP signal tube as well. The shorter the better.
Old May 13, 2005 | 02:41 AM
RSblkcam's Avatar
Car: 1991 Formula
Engine: 350 HSR
Oh, that is much clearer about the FPR deal. As for the HVAC, is that the small black rectangular box that has a small hose going to an intake fitting and has the MAP fitting? Also, I don't have a FPR gauge, so how would I go about finding the right pressure to just get it running properly (I will have a gauge asap)?
Old May 13, 2005 | 03:27 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'm not sure what black box you're talking about but I know on my car the HVAC controls didn't come out of any box, they came straight out of the wire loom harness back near the rear of the passanger side head. It's a real small diameter plastic tube. Smaller than a regular straw.
The screw on the AFPR just sets the base pressure (what it is at WOT I believe) so if you've got the hose hooked up to it just set it halfway or something until you get a guage (but get that as soon as possible) Are you hooking up a temp guage to set it or runnning a permanent one?
Old May 13, 2005 | 05:53 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Set the FPR to 50psi with vac disconnected, then tune from there on. 50psi is the generic "magic spot" that a lot of injectors spray really nice at. That will be your 100kpa (for n/a cars) WOT pressure.
Some like more, some like less (for spray pattern, not fuel delivery - thats done with injector pulse width), but you'd really need to tune on a dyno to get much better.
-- Joe
Old May 13, 2005 | 10:33 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
...If he's got no guage to tell what the pressure is, how does he do that?
Old May 13, 2005 | 01:15 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Rent one from autozone for free.
-- Joe
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Aug 25, 2015 09:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
L98GTA87
Aug 11, 2015 06:55 PM
