Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Stock Distributor With HSR Intake
Old Apr 30, 2005 | 02:47 PM
klumb15's Avatar
I was gonna put my motor in today, but right before i was gonna drop it in, i put the distributor in, or atleast tried...and it wouldn't go in...the distribitor housing was interferring with the back upright of the the HSR manifold...there isn't enough clearance...is this a common problem? why won't the stock one go in? Do I need a new one, and if so what can i use? the engine is a 89 vette engine..
Old Apr 30, 2005 | 06:05 PM
bubba353z's Avatar
Car: 07 Honda CR-V
Engine: Yes, there's one in there...
Transmission: One that shifts itself
The HSR requires a small cap distributor - with a separate coil. I bought a MSD 8366 to replace the HEI that was acting up in my car.
I'm not sure what distributor you have, but if the coil is in the cap, then that is your problem.
Old Apr 30, 2005 | 06:20 PM
klumb15's Avatar
yup i got the coil on top of the cap....is there anything a little cheaper that i can go with instead of the MSD....thats a like a 300 dollar distributor...
Old Apr 30, 2005 | 06:55 PM
rsn932's Avatar
try the classifieds for a used stock one. i see them on there pretty frequently for cheap money.
Old Apr 30, 2005 | 07:26 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
And if the magnets aren't quite there you can always rebuild them cheaply enough.
A Junkyard should have what you need too, you can buy an aftermarket coil while you are at it.
Make sure you grab the associated wireing while you are at it.
Old Apr 30, 2005 | 09:30 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Summit sells a summit brand small cap HEI distributor for $200 part number SUM-850008 and summit sells an accel HEI distributor for $240 part number ACC-60109
Old May 1, 2005 | 12:14 AM
BadSS's Avatar
They also sell a Proform part number PRO-66939BK for $146.
Old May 1, 2005 | 06:27 PM
laiky's Avatar
brand new from gm about $165
Old May 1, 2005 | 09:47 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
and if yur lookin for nothin special....autozone has em cheap somewhere around $100. donno if that comes with a cap and rotor though.
Old May 13, 2005 | 01:56 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Just for completeness the GM part number: 1103952 or 1104060. Does anyone know which is the correct number.
Old Apr 28, 2006 | 05:07 AM
Dwalk47's Avatar
Thread Resurrection....
Just for clarification, will any/all of these distributors work with the C950 to use its computer for advance?
Thanks-
Dan
Old Apr 28, 2006 | 08:29 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I decided to go with a 60's points type that I quickly converted to the mangetic/electronic with the petronics kit. I know I will get a EST code but the advance will be handled via vacuum port.
Old Apr 28, 2006 | 11:26 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Also on the remote coil units, the cap can extend away from the housing enough to hit the back wall. This was limiting the amount the dizzy could rotate back there. I had to grind off a small amount of plastic (1/8" -1/4") near the cap retaining screw where it was molded out too far.
(Summit, red cap)
Still have to set the base to know if I really needed to do that.
But at least now it can turn freely.
Old Apr 30, 2006 | 07:00 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
i bought a Holley Small cap billet dist. before they stop building electronics. But you can get a stock Dist. and a aftermarket ingintion system. i use a Crane HI6 with the L92 coil. them were sold together. you can get all three from around 300. i think. just a thought.
Old Apr 30, 2006 | 10:44 AM
Dwalk47's Avatar
After looking and researching a bit more...
I think that I'm going to buy the summit stock replacement distributor SUM-850008 for the 88-92ish V8 used in the Camaro, and use the same Blaster 2 coil, along with the holley adaptor for that plug. I believe that this should work, chime in if not!
1992 Trans Am
May 10, 2023 07:19 PM
ASE doc
Aug 25, 2015 09:14 AM
Out-Cast
Aug 17, 2015 10:57 AM
cstrobel65
Aug 15, 2015 10:19 AM
stalkier
Aug 7, 2015 04:49 AM
