Another Air Dyno Request
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Anyone wanna make a guess to my cars hp?
1988 Irocz L98
Stock heads have been fully ported gasket matched to Felpro 1205, 3 angle valve job.
Milled to lower the cc to 60cc. FelPro copper head gaskets .039" thickness
1.6 roller tip rockers
stock cam
Holley Stealth Ram intake ported and gasket matched to FelPro 1205
52mm TB, with coolent bypass
Ram air airbox mod with K&N's
Headmen shorty headers, y pipe, Catco cat 3" cat back with Dyno max muffler.
MSD Coil, cap, wires
LS1 28.5lb injectors
Smog pump delete
Custom chip
Any ideas?
1988 Irocz L98
stock cam
Smog pump delete
Custom chip
Any ideas?
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
hey i was lookin to to similar set-up as u with the stealthram ...for now.....and i was wondering how u liked it with the gasket matched heads? i already did that to my heads, and am thinkin about gettin the stealthram soon to get rid of the tpi....did u notice a big dif? thanx for the help too
dave
dave
Car: 1971 Camaro
Engine: 427
I haven't really had a chance to try it out, car went straight to the paint booth once it was running.
It sounds, feels and acts much healthier. Revs real quick now.
i'm gonna say maybe 300-325 at the crank...that stock cam is probably holding you back...i have almost the same setup but L98 alum heads and 276HR cam, and some people rated it at like 375 or so...
Car: 1971 Camaro
Engine: 427
Originally posted by Free Bird
Don't know if you've noticed, but most valves come w/ a 3 angles cut on them.
?? Even stock?
Car: 1971 Camaro
Engine: 427
Well, the reason I asked is a member has one for sale. Looked like a good size cam for my application.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
oh, well in that case
Some people have had really good luck w/ that came. You won't see the full potential untill you get heads, but it will be a big upgrade from stock.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I agree with Freebird. The ZZ9 is OK but you need heads to see the full potiential. Stock gasket matched heads and a 3 angle valve job is not full potiential.
Car: 1971 Camaro
Engine: 427
I know my heads are not as good as Darts or AFR's but they have had more done than gasket match. They have been fully ported with a lot of reworking done on the radius's and under the valves. Got to look up my flow charts, but thy did very well.
tonys91rs
Oct 10, 2015 03:31 PM
