Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR sensor placement
Old Sep 26, 2005 | 12:58 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I have canfield heads on my car so I dont have any holes in my heads for Fan switch and Temp sender so, I have put all three sensors (CTS/gauge/fan) on the front of my HSR and then I put the heater hose to the upper hole on the waterpump just to have it connected.
But now I wont get any heat in my car so I guess I have to move the heater hose to the intake, this mean I have to move 1 sensor to another location, where?
If I drill a hole and tap it where the coolant ports are blocked off by the intake on the back of the heads what sensor should I move to this location the get the most accurate reading from it, or any other ideas?????
/N.
Old Sep 26, 2005 | 01:12 AM
Z69's Avatar
Z69
Over here, you can buy tstat housings tapped for a sensor.
I went and looked at my hsr.
Tap the flat pad on the left side just below the 3/8 hole on the front of the intake.
As long as you never plan on running a short WP and pre 69 brackets you'll never have a problem.
That should give you 4 spots to use.
I still haven't figured how you did the heater with only one hose.......
Or do 3rd gen wp's have two connections on the pump?
Old Sep 26, 2005 | 01:21 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I have an old style water pump( heater return line goes to radiator, heater inlet from intake)............. anyone know what thread size it is? then I can reuse my connector.......... and buy a plug.............
/N.
Old Sep 26, 2005 | 01:57 AM
Z69's Avatar
Z69
Heater hose is usually 1/2" NPT.
The rt hand hole on my HSR is 1/2".
The left hand one is 3/8"NPT- for a sensor
I forgot about the tank connection for the return.
Only been about 10yrs since I had a 3rd gen.
I wonder what a NPT tap goes for in Sweden?
Old Sep 26, 2005 | 02:05 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
You dont want to know what US stuff coste here in sweden gas is now 6.3$/gallon
I'll see what taps I can find here at work (volvo)..............
db057
Jan 10, 2020 08:55 PM
bbsr72
Apr 2, 2016 09:12 AM
1nastygta
Sep 24, 2015 08:58 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Night rider327
Sep 16, 2015 02:20 AM
